Compared to the cost of a decent 4k rig setup the cost of such an optical drive is just dust. My advice: Buy one of those LG based drives and move on.mmkav wrote: Thu Jan 07, 2021 1:51 pmI know, but this platform RS1013, LibreDrive on it maybe in the future is discussed here in conjunction with HD DVD.Woodstock wrote: Thu Jan 07, 2021 1:40 pm At present, there is no LibreDrive support for ANY Pioneer drive, so the RSxxxx platforms do not have any firmware packages.
I posted my question here because I hope someone familiar with it has a recommendation for a newer firmware version and/or Cross Flash and can answer my question if HD DVD can be archieved by Cross Flash, I found info that it works for other models but no one confirmed or denied for this model.
My poor ancient HD-DVD/BD Combo!
Re: My poor ancient HD-DVD/BD Combo!
mmkav
That is not the point of this thread, I have the drive I mentioned (among others) and want to make the best of it, maybe in the future with LibreDrive and now with a Cross Flash if this makes sense.
SandyD
I have one of those RS1013 drives as well and interested.
mercennarius
Second! Happy to beta test or send a spare drive if needed to get this going.MetalDave wrote: Sat Jan 02, 2021 11:13 pm
If there's anything I can do to contribute to this effort, please advise!
Related:
https://club.myce.com/t/lg-blu-ray-cros ... u11/238076
mercennarius
Bump. Any updates on possible firmware mods for these drives? Be awesome to see libredrive, and HD DVD writing capability added to them. Thanks!
BTW, there's a brand new LG GGW-H20L dual HD DVD/Blu Ray drive on ebay right now:
https://www.ebay.com/itm/LG-Blu-ray-Dis ... SwL3BgQTAd
mercennarius
Bump. Would love libredrive support for these drives.
LibreDrive won't gain you anything on a drive that is from 2014 or earlier, really. It's the ones built after 2015 where you might gain some functionality, and then only if it was a drive that supported UHD. My Pioneer drive (2015) had no functionality added to it.
mercennarius
It would allow you to play HD DVDs without searching for defunct software or using something like AnyDVD.Woodstock wrote: Wed May 11, 2022 4:59 pm LibreDrive won't gain you anything on a drive that is from 2014 or earlier, really. It's the ones built after 2015 where you might gain some functionality, and then only if it was a drive that supported UHD. My Pioneer drive (2015) had no functionality added to it.
MadCritter
Did you ever end up trying this? Any luck? I've got an SD-H903a also taken from one of those machines on the way and I'm not sure it'll work. You ever had any luck with the 912 burning anything? I'm really keen to burn actual HD-DVDs, and I have a lot blank media. I'd like to find the firmware for the 903 if possible, but it's not exactly easy. Any help you can give is great. As well, if you're willing to sell it, I'd totally buy your 912.Blackened2687 wrote: Wed Jun 24, 2020 5:47 am BTW, I personally have Toshiba SD-H903A HD DVD-R drive pulled from Japanese standalone HD DVD-R recorder, but its command system appears to be incompatible with generic PC burning/reading software, the drive refuses to write anything except lead-in to HD DVD and, thus, corrupts the expensive and hard-to-find today HD DVD-R media. I wonder, if it's possible to do something about it?
Maybe it's possible to extract and patch its firmware to make it work on PC? I don't know, if the firmware dump from laptop HD DVD burner from Toshiba could help in this task. I have it myself, too (SD-L912A).
Mercilesswaysdesigns
Late to the party but does the LG GBW H20L rip 4k Blu-Rays? It just needs to be flashed or cross flashed?
No, no ,no. It is simply far too old and not the right hardware.Mercilesswaysdesigns wrote: Sun Oct 06, 2024 12:28 am Late to the party but does the LG GBW H20L rip 4k Blu-Rays? It just needs to be flashed or cross flashed?
Thanks! Dodged that bullet I almost bought one.MartyMcNuts wrote: Sun Oct 06, 2024 4:02 amNo, no ,no. It is simply far too old and not the right hardware.Mercilesswaysdesigns wrote: Sun Oct 06, 2024 12:28 am Late to the party but does the LG GBW H20L rip 4k Blu-Rays? It just needs to be flashed or cross flashed?
Swanfrt
Hey guys, I get the fact that theses drives can't rip uhd, but can they rip standard Blu-ray? Thanks !
EinEcho
Hello
I am new to this and just found a LG BP40NS20 in some things we sorted out.
I was wondering are there any news about the LibreDrive Support for the RS1013.
Yes, of course but since they are 15+ years old, not sure for how much longer.Swanfrt wrote: Wed Nov 26, 2025 1:03 pm Hey guys, I get the fact that theses drives can't rip uhd, but can they rip standard Blu-ray? Thanks !
