Thank You. The drive is almost new and seems good but I did go for the cheapest solution so maybe I'll try another model. I still have an old external LG Blu Ray drive that I used for Blu Rays and it seemed much better so that's why I thought LG would be good and maybe they are but not this particular drive.Billycar11 wrote: Fri Mar 05, 2021 11:11 pmHash file wrong means you got a read error not that the key was not availablebhampster wrote: Fri Mar 05, 2021 3:18 pmI believe it's this one.
LG WH14NS40
I can try Tenet again later, if I read the thread correctly a dump file was sent for the amazon US version I have.
TENET UHD RB - Failed to open disk
bhampster
Re: TENET UHD RB - Failed to open disk
bhampster
I had a world of problems with this disc. I bought a new drive which didn't help.
Eventually I had to rebuy the disc. Then it worked first try.
I think I may need to rebuy Top Gun also which thankfully is much cheaper. I'll definitely examine discs AS SOON AS I GET THEM going forward.
WibsWobs
Anyone have the US version from Best Buy working? I got 59 read errors... Fun fun. Getting ready to return the disk and try a diff copy.
UHD_135515_Tenet_UHD01
As for drives, I have the S60 (WH16NS60)
I also have online access granted.
errors are different than not opening the discWibsWobs wrote: Thu Aug 12, 2021 5:19 am Anyone have the US version from Best Buy working? I got 59 read errors... Fun fun. Getting ready to return the disk and try a diff copy.
clean the disc
get new disc
clean drive
get BU40N
lot of those defective WH16NS60s around
WibsWobs
Maybe I should have posted in a different thread then.
The drive is fine, the 25 other UHDs I ripped recently all were fine. Maybe this drive can't do this disk or ... The disc and the replacement were both immaculate, 50+ read errors on both.
I'll just return it and buy a blu ray version cheap. The time cost alone is more than the price I paid for the movie.
Maybe the 25 others were not bd 100s like this movie is.WibsWobs wrote: Sat Aug 14, 2021 10:40 pm Maybe I should have posted in a different thread then.
Some drives only have problems with bd100s
I have had drive that would rip every bd 66 I had then get read errors on a bd 100
