Open DVD manually and setting titles by numbers only shows first title in results
Jeff72
Post by Jeff72 » Fri Mar 05, 2021 10:00 pm
I just upgraded to MakeMKV BETA 1.16.1 and now when I click on "Open DVD manually" I see a bunch of titles listed and I manually enter the numbers for the tracks I want then hit OK but it only finds the first track I listed now. Is this a bug?
For example, if I select "2 5 7" for titles 2, 5 and 7, then hit OK, then the found options only shows the first title 2 to be copied.
Any suggestions?
Also, version 1.15.4 was what I used previously and that one worked as expected...it would show results for all 3 titles in the above example.
KeithG502
Re: Open DVD manually and setting titles by numbers only shows first title in results
Post by KeithG502 » Wed Mar 17, 2021 11:59 pm
I'd like to report similar results.
For example, I attempted to open the "Honest Thief" DVD. Using VLC I determined that title 22 is the movie. I manually opened the DVD, entered 22 and ended up back at the Open Disc window. I then pressed Open Disc without the manual check box selected and MakeMKV found the movie as Title 22.
I next tried "VeggieTales Holiday Double Feature", manually entering titles 1 and 22. This time only Title 1 opened (like Jeff22 reported). Having MakeMKV open the disc without the manual check box selected opened both Title 1 and 22 (along with another title).
v1.16.0 also exhibited this behaviour.
zeroryouko
Post by zeroryouko » Sun Mar 21, 2021 10:23 pm
This is happening for me as well. Except it seems like only the first character of the string is used. I have a DVD where the correct titles are 39 and 2. So I entered 39: 2: as the string to open, and it tries to open title 3.
