Submitted multiple UHD dumps, keys are unresolved
troglodyte
#1 Post by troglodyte » Fri Mar 05, 2021 3:21 pm
I have been submitting dumps for UHD failing with volume key unknown to the email svq@makemkv.com
TENET UHD
GHOST IN SHELL etc.
It has been few weeks and I have resubmitted as well without any luck so far
Please advise.
Re: Submitted multiple UHD dumps, keys are unresolved
#2 Post by Woodstock » Fri Mar 05, 2021 3:26 pm
Are you seeing any errors about not being able to retrieve the hash key file? Those titles have been ripped by others.
troglodyte
#3 Post by troglodyte » Fri Mar 05, 2021 3:59 pm
For e.g. for TENET, this is what I see when I tried just now
Using LibreDrive mode (v06.2 id=0FA242DD4D0B)
Downloading latest HK to C:\Users\nmryzen/.MakeMKV ...
Saved AACS dump file as C:\Users\xxxxxxxxx/.MakeMKV/MKB20_v76_Tenet_E37B.tgz
#4 Post by Woodstock » Fri Mar 05, 2021 4:54 pm
You're not getting the keys after the submission.
Make sure you haven't disabled internet access (Preferences->General)
Make sure your DNS resolution is set to use at least one that doesn't block resolution of certain domains (Google's 8.8.4.4. and 8.8.8.8 work, Cloudflare's 1.1.1.1 filters out domains they don't like, and a lot of ISP DNS servers are similarly filtered).
There's a long topic on this elsewhere. The hash key table is hosted on hkdata.fairuse.org . At a CMD prompt, type the following and see if you get an IP back:
nslookup hkdata.fairuse.org
The result should look like this:
C:\>nslookup hkdata.fairuse.org
Server:  UnKnown
Address:  192.168.4.10
Non-authoritative answer:
Address:  91.224.23.225
troglodyte
#5 Post by troglodyte » Fri Mar 05, 2021 5:21 pm
I did make sure to check the 'enable internet access' option
I have changed it to 8.8.8.8 and flushed the DNS Cache on my PC
It has responded as below
Server:  localdomain
Address:  192.168.1.1
I am sorry but no luck still ! ..
#6 Post by Woodstock » Fri Mar 05, 2021 5:30 pm
The other likely candidate is "region blocking" by your firewall. That IP is hosted in Russia, so that may be an issue with how your system is configured.
This site is also hosted in Russia, but everyone accesses it through a Cloudflare IP that isn't.
troglodyte
#7 Post by troglodyte » Fri Mar 05, 2021 5:38 pm
Woodstock wrote: Fri Mar 05, 2021 5:30 pm The other likely candidate is "region blocking" by your firewall. That IP is hosted in Russia, so that may be an issue with how your system is configured.
Wow ! .. this was it. I had a GeoIP filter on from some countries ..
Highly appreciate your timely response !!!!
DiscworldDenizen
#8 Post by DiscworldDenizen » Wed Mar 10, 2021 11:55 am
Hi! I am having the same problem as troglodyte, except that the hashes I submitted ("Flash Gordon - 40th Anniversary" 4K standard edition and "Alita - Battle Angel" 4K) on 1st March 2021 do not seem to have been processed. I checked that I could access the sites "makemkv.com" and "hkdata.fairuse.org." I have selected the "Enable Internet Access" option and am not getting the "Automatic HK downloading is disabled or failed" error. I have changed my DNS to use Google's DNS servers (8.8.8.8 / 8.8.4.4).
Everything seems to be setup correctly from my perspective - can anyone help, please?
DiscworldDenizen
#9 Post by DiscworldDenizen » Thu Mar 18, 2021 7:37 pm
I never found a solution to being unable to rip 4K discs with my Windows XP setup, so I tried a workaround. I created an Ubuntu live disc, installed the MakeMKV snap package on it and managed to rip my two 4K discs ("Flash Gordon - 40th Anniversary" and "Alita - Battle Angel"). Using the same machine and network settings, the rip succeeded without a hitch. Hmmm. All's well that ends well.
