TENET UHD RB - Failed to open disk
Wire1078
Re: TENET UHD RB - Failed to open disk
#106 Post by Wire1078 » Fri Jan 15, 2021 12:21 pm
Do keys for the uhd disks get automatically added to the software?
Or do you have to add them manually?
Struggling with Tenet and Blade UK versions
#107 Post by d00zah » Fri Jan 15, 2021 12:34 pm
Wire1078 wrote: Fri Jan 15, 2021 12:21 pm Do keys for the uhd disks get automatically added to the software?
UHD FAQ
Refer to section Hashed Keys
by96$
#108 Post by by96$ » Sat Jan 16, 2021 12:17 am
by96$ wrote: Wed Jan 13, 2021 11:34 pm I just received Tenet from Amazon and am having problems ripping it or backing it up. I continually get an error message:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading...
Again, this happens with ripping or just backing up. I have cleaned the disc (will try that again) and have never had this problem on any other disc.
UPDATE: I cleaned the disc several times and tried backing it up. Nothing worked. Always got the same error message. Once, it got half way through the back up and then failed. I have requested a new copy from Amazon to see if a different disc works. Any help would be appreciated.
As another update, I received the second disc from Amazon today and so far, it is ripping without error or problem. Guess the discs do make a huge difference. Fortunately, Amazon exchanged discs without any hassle.
JulesKeeper
#109 Post by JulesKeeper » Fri Jan 29, 2021 11:31 pm
I bought TENET 4K UHD and I'm unable to open the disc. I've tried the normal way from the MakeMKV app and via the Backup method and neither approach worked.
Screenshot:
MakeMKV - TENET.JPG (97.46 KiB) Viewed 39509 times
I've emailed the dump file.
Any suggestions?
preserve
#110 Post by preserve » Sat Jan 30, 2021 4:07 am
JulesKeeper wrote: Fri Jan 29, 2021 11:31 pmI've tried the normal way from the MakeMKV app and via the Backup method...
Any suggestions?
Per the stickied FAQ, now that you’ve submitted the dump file, wait for the hashed key to be updated for the particular disc you have.
In the meantime, if you want to, you should be able to make a backup without decrypting the video, which allows you to sort out any potential disc cleaning issues and once the key is available, you can open the backup rather than the disc.
Using: ASUS BW-16D1HT 3.00
JulesKeeper
#111 Post by JulesKeeper » Sat Jan 30, 2021 5:25 pm
preserve wrote: Sat Jan 30, 2021 4:07 am
Any suggestions?
Working now! Thank you to whoever made the Hashkey available.
RobertHQ
#112 Post by RobertHQ » Wed Mar 03, 2021 9:23 pm
I have the same problem with the disc. Can someone here help me with this?
Laufwerksinformation
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: HL-DT-ST
Produkt: BD-RE WH16NS60
Revision: 1.00
Serienummer:
Firmware-Datum: 2117-04-25 17:56
Markierungen der Bus-Verschlüsselung: 17
Highest AACS version: 76
Firmware version: 1.00
Disk-Informationen
Label: TENET
Zeitstempel: 2020-11-05 11:20:51
Datenkapazität: 82.73 Gb
Disk-Typ: BD-ROM UHD
Anzahl der Layer: 3
Markierungen der Bus-Verschlüsselung: 80
#113 Post by dcoke22 » Wed Mar 03, 2021 10:31 pm
RobertHQ wrote: Wed Mar 03, 2021 9:23 pm I have the same problem with the disc. Can someone here help me with this?
You need to email the dump file that was generated to svq@makemkv.com. UHD FAQ: https://www.makemkv.com/forum/viewtopic ... 12&t=16883
RobertHQ
#114 Post by RobertHQ » Thu Mar 04, 2021 6:02 am
Thanks, I did that, but unfortunately I haven't received any feedback yet.
#115 Post by SamuriHL » Thu Mar 04, 2021 4:14 pm
Nor will you. If you're expecting some kind of response, you're not going to get one. The key will be added whenever Mike gets to it and at that point it'll just start working assuming MakeMKV is set to automatically update the key database.
bhampster
#116 Post by bhampster » Fri Mar 05, 2021 10:48 am
No luck with mine and it's from Amazon and behaves identical to one of the previous posts in this thread.
If I back up or try to rip it says one of the hash files is wrong. The disc looks perfect and plays fine in my UHD BDP but I boiled and cleaned it anyway.
Looks like I bought a bad version.
#117 Post by Billycar11 » Fri Mar 05, 2021 11:31 am
What drive do you have?
RobertHQ
#118 Post by RobertHQ » Fri Mar 05, 2021 12:44 pm
WOW Now I can key my disk thanks for the tip with the upload and the MakeMKV online the key contacts.
bhampster
#119 Post by bhampster » Fri Mar 05, 2021 3:18 pm
Billycar11 wrote: Fri Mar 05, 2021 11:31 am What drive do you have?
I believe it's this one.
LG WH14NS40
I can try Tenet again later, if I read the thread correctly a dump file was sent for the amazon US version I have.
#120 Post by Billycar11 » Fri Mar 05, 2021 11:11 pm
bhampster wrote: Fri Mar 05, 2021 3:18 pm
LG WH14NS40
Hash file wrong means you got a read error not that the key was not available
