I know, I'm late to the party. I'm unable to rip Mockingjay Part 1. I've tried 553.mpls, 697.mpls, and 707.mpls. None work. I'm not technical – I don't even know what a segment is – so I don't really know what I'm looking for. MakeMKV 1.10.2 even points you to the "main feature," and it won't work. (The main feature is 697.mpls.)
I'm on a Mac.
Any guidance would be appreciated. Thanks!
Hunger Games Mockingjay Part 1 - US Retail (title)
Vandement
abirdie4me
Re: Hunger Games Mockingjay Part 1 - US Retail (title)
You are awesome! I created an account on this forum to say THANK YOU, you saved me a ton of time. I have this exact UPC from Walmart and tried 4 combinations of Hunger Games that were wrong before finding this post.woodmtw wrote: I purchased the 6-Disc Blu-ray + Digital HD "The Hunger Games, Complete 4-Film Collection" from Walmart in Utah, USA on 4/2/2016.
The UPC code is 0 31398 23837 9.
Here are the correct .mpls numbers:
eikki
Hey me too! can anyone please helpVandement wrote:I know, I'm late to the party. I'm unable to rip Mockingjay Part 1. I've tried 553.mpls, 697.mpls, and 707.mpls. None work. I'm not technical – I don't even know what a segment is – so I don't really know what I'm looking for. MakeMKV 1.10.2 even points you to the "main feature," and it won't work. (The main feature is 697.mpls.)
I'm on a Mac.
sveighten
For those looking, keep in mind that makemkv doesn't sort by mpls, so you might have to look around. I found 696 and 699 or something and assumed that 697 was missing. Turns out the list just wasn't sorted.IrishPrince wrote:As an academic exercise I tried the Netflix version of Mockingjay Part 1. The correct title is 697:
Name: The Hunger Games: Mockingjay - Part 1
Source file name: 00697.mpls
Duration: 2:02:50
Chapters count: 16
Segment count: 20
Segment map: 510,512,519,504,517,505,507,513,520,502,516,509,508,518,503,506,501,515,511,514
File name: The_Hunger_Games_Mockingjay_-_Part_1_t417.mkv
efmullen
Ripped the below and watched whole movie side by side with BluRay. Everything matched up correctly. Good luck! Thank you everyone for your help!
UPC:0 31398 20644 6 80
Title information
Source file name: 00553.mpls
Duration: 2:02:50
Chapters count: 16
Segment count: 20
Segment map: 503,520,516,510,511,506,507,514,518,509,519,517,501,505,502,512,515,504,513,508
File name: The Hunger Games- Mockingjay - Part 1_t293.mkv
Title information
Duration: 2:02:50
Chapters count: 16
Segment count: 20
libreme
How do you guys identify segments and how do you determine which is the correct one?
Poker354
Read the thread "A better way to find the correct playlist/segment map" found in the "MKV file processing and playback" section.libreme wrote: Wed Oct 23, 2019 4:07 am How do you guys identify segments and how do you determine which is the correct one?
libreme
00553.mpls didn't work for meefmullen wrote: Wed Oct 02, 2019 8:05 pm Ripped the below and watched whole movie side by side with BluRay. Everything matched up correctly. Good luck! Thank you everyone for your help!
Title information
Duration: 2:02:50
Chapters count: 16
Segment count: 20
jstrot
I think you're mistaken, I believe the correct playlist is 302 (not 320) for the Canadian eOne version. UPC: 7 74212 93644 9Chilkoot wrote: Thu Aug 20, 2015 7:05 pmI went through the same exercise and you're memory's spot on. For the Canadian EOne version:Batiatus wrote:I figured out the Canadian Eone disc by ripping a couple versions, going through each scene and figuriing out where the streams change and then setting up the proper order. Had it written down and ripped it to find it was perfect. Then forgot to update here and my garbage has been taken out. D'oh! I 'think' it was like 320 or something. Lionsgate is just dumb for doing this though. Stupid dumb.
Hopefully this saves someone else the pain of undiscombobulating the whole mess again!Code: Select all
Playlist: 320 Filename: t176 Order: 519 514 509 511 501 518 510 502 507 506 503 512 508 517 504 515 513 516 505 520
Title information
Name: The Hunger Games: Mockingjay - Part 1 (English)
Source file name: 00302.mpls
Duration: 2:02:50
Chapters count: 16
Segment count: 20
Segment map: 519,514,509,511,501,518,502,510,507,512,506,503,508,504,517,515,513,516,505,520
I just went through this exercise on Linux:
- extract a decrypted backup: makemkvcon backup --decrypt dev:/dev/sr1 backup-folder
- extract the info to a text file: makemkvcon info --robot file:backup-folder > info.txt
- isolate and sort segment orders: grep -E 'TINFO:[0-9]+,26,0,' info.txt | sort -t , -k 4 > orders.txt
- being sorted, the segments are like a tree... manually go through the segments, checking against the movie playing on a physical BD player, adding up lengths to track the position and prune "branches" as you go until you're left with only one possibility
- the first number on the "winning" TINFO line is the title number, look for TINFO:<title#>,16, in the info.txt file to get the corresponding playlist
Once the backup was extracted, the rest of the process took about 10 minutes.
Cave Man
I have this same UPC Blu-ray Disc but the segment map is different for t293:efmullen wrote: Wed Oct 02, 2019 8:05 pm Ripped the below and watched whole movie side by side with BluRay. Everything matched up correctly. Good luck! Thank you everyone for your help!
Title information
Duration: 2:02:50
Chapters count: 16
Segment count: 20
503,519,511,502,514,510,512,518,515,504,513,506,505,501,517,520,509,507,516,508
Will t293 still work, or do I need to figure out another title track?
Usually what you're looking for is a title that has the same segment map, not the same title name. So look through the other titles until you find the one with the same segment map.
eshcabeebee
Source file name: 00707.mpls
Duration: 2:02:50
Chapters count: 16
Segment count: 20
File name: The Hunger Games- Mockingjay - Part 1_t379.mkv
This is the one that worked for me with the upc code 03139820644680.
Duration: 2:02:50
Chapters count: 16
Segment count: 20
azbiker57
Looks like I may have a different US retail version than some others.
UPC: 0 31398 20925 6
Source File: 00697.mpls
Duration: 2:02:50
Chapter Count: 16
Segment Map: 510,512,519,504,517,505,507,513,520,502,516,509,508,518,503,506,501,515,511,514
Duration: 2:02:50
Chapter Count: 16
Xehelios
For the BD in the UHD/BD set sold on Amazon Canada
UPC: 0 31398 25278 8 82
Duration: 2:02:50
Chapters count: 16
Segment count: 20
File name: The Hunger Games- Mockingjay - Part 1_t141.mkv
And for those who are new to this, here's how to get to it. Assuming you are on macOS, have VLC, and it can play Blu-ray discs, run
Then, in the newly opened VLC window, press Cmd+D to open disc (or File -> Open Disc), open the BD disc, and then play the movie. The right .mpls file name will appear in the terminal. Quit VLC.
Then, (assuming you already have a decrypted backup of your disc that you made with MakeMKV) , in the Terminal
Then run
You can then open the info.txt file and search for the .mpls and see the Title number associated with it. Since MakeMKV sorts by title number, that makes finding the right playlist far easier.
Duration: 2:02:50
Chapters count: 16
Segment count: 20
env -u JAVA_HOME BD_DEBUG_MASK=0x40 /Applications/VLC.app/Contents/MacOS/VLC 2>&1 | grep -i mplsThen, (assuming you already have a decrypted backup of your disc that you made with MakeMKV) , in the Terminal
cd /Applications/MakeMKV.app/Contents/MacOSCode: Select all
./makemkvcon info --robot file:"folder of your decrypted backup" > ~/Desktop/info.txt
