How to flash a BU40N_1.01?
pmhCH
Post by pmhCH »
Hi all
Help me before I will brick my drive:
My drive is following:
Pierre-Maries-MacBook-Pro:MacOS pmheller$ ./makemkvcon f --list
Found 1 drives(s)
00: /IOBDServices/11B1380F
HL-DT-ST_BD-RE_BU40N_1.01_211910161032_MO5KCTF2216
I have the HT-DT-ST folder in "Downloads"
So which syntax/file is correct being in the folder I am now? I read about downgrading from 1.01 to 1.00 then I read about 1.04 to be the one to go...
What is correct? ;)
PS: I am now in: /Applications/MakeMKV.app/Contents/MacOS
Samsung 78" (still with 3D), ATV 4k (64Gb) running Infuse, Hue Sync + Sonos "5.1"
Re: How to flash a BU40N_1.01?
This is a reasonable example for flashing a drive on a Mac: https://www.makemkv.com/forum/viewtopic.php?f=4&t=23129
The Ultimate UHD Drives Flashing Guide Updated 2021 (https://www.makemkv.com/forum/viewtopic ... 16&t=19634) suggests putting BU40N drives on 1.03MK. Others on this forum know a lot more than me about drive firmware, however.
pmhCH
Post by pmhCH »
dcoke22 wrote:
Thu Mar 04, 2021 9:01 pm
So the idea is to go from 1.01 up to 1.04 and not downgrade to 1.00?
The Drives Guide, linked above, is kept up to date by the folks who know the most about drive firmware. That guide says:
BU40N on any Firmware directly to > BU40N 1.03MK
It doesn't say anything about 1.00 or 1.04. The guide is detailed and informative.
pmhCH
Post by pmhCH »
dcoke22 wrote:
Thu Mar 04, 2021 9:11 pm
There's no 1.03-file anymore in the newest pack, only 1.04 - tried it now and it worked ;)
Thanks to all for your help!
pmhCH wrote:
Thu Mar 04, 2021 9:27 pm
The best firmware for the BU40N is DE_LG_BU40N_1.00. This firmware is compatible with the most software.
pmhCH
Post by pmhCH »
MartyMcNuts wrote:
Thu Mar 04, 2021 10:40 pm
So could I flash the DE_LG_BU40N_1.00 over the 1.04? Or are there some risks? I only use the drive for makeMKV so perhaps it is not necessary?
pmhCH wrote:
Fri Mar 05, 2021 9:19 am
it wont work over 1.04 unless it 1.04mk
but not needed unless you use other rippers
