How to flash a BU40N_1.01?
pmhCH
#1 Post by pmhCH » Thu Mar 04, 2021 8:57 pm
Hi all
Help me before I will brick my drive:
My drive is following:
Pierre-Maries-MacBook-Pro:MacOS pmheller$ ./makemkvcon f --list
Found 1 drives(s)
00: /IOBDServices/11B1380F
HL-DT-ST_BD-RE_BU40N_1.01_211910161032_MO5KCTF2216
I have the HT-DT-ST folder in "Downloads"
So which syntax/file is correct being in the folder I am now? I read about downgrading from 1.01 to 1.00 then I read about 1.04 to be the one to go...
What is correct? ;)
PS: I am now in: /Applications/MakeMKV.app/Contents/MacOS
Samsung 78" (still with 3D), ATV 4k (64Gb) running Infuse, Hue Sync + Sonos "5.1"
Re: How to flash a BU40N_1.01?
#2 Post by dcoke22 » Thu Mar 04, 2021 9:01 pm
This is a reasonable example for flashing a drive on a Mac: https://www.makemkv.com/forum/viewtopic.php?f=4&t=23129
The Ultimate UHD Drives Flashing Guide Updated 2021 (https://www.makemkv.com/forum/viewtopic ... 16&t=19634) suggests putting BU40N drives on 1.03MK. Others on this forum know a lot more than me about drive firmware, however.
pmhCH
#3 Post by pmhCH » Thu Mar 04, 2021 9:04 pm
dcoke22 wrote: Thu Mar 04, 2021 9:01 pm This is a reasonable example for flashing a drive on a Mac: https://www.makemkv.com/forum/viewtopic.php?f=4&t=23129
So the idea is to go from 1.01 up to 1.04 and not downgrade to 1.00?
#4 Post by dcoke22 » Thu Mar 04, 2021 9:11 pm
The Drives Guide, linked above, is kept up to date by the folks who know the most about drive firmware. That guide says:
BU40N on any Firmware directly to > BU40N 1.03MK
It doesn't say anything about 1.00 or 1.04. The guide is detailed and informative.
pmhCH
#5 Post by pmhCH » Thu Mar 04, 2021 9:27 pm
dcoke22 wrote: Thu Mar 04, 2021 9:11 pm The Drives Guide, linked above, is kept up to date by the folks who know the most about drive firmware. That guide says:
There's no 1.03-file anymore in the newest pack, only 1.04 - tried it now and it worked ;)
Thanks to all for your help!
#6 Post by MartyMcNuts » Thu Mar 04, 2021 10:40 pm
pmhCH wrote: Thu Mar 04, 2021 9:27 pm
The best firmware for the BU40N is DE_LG_BU40N_1.00. This firmware is compatible with the most software.
pmhCH
#7 Post by pmhCH » Fri Mar 05, 2021 9:19 am
MartyMcNuts wrote: Thu Mar 04, 2021 10:40 pm
So could I flash the DE_LG_BU40N_1.00 over the 1.04? Or are there some risks? I only use the drive for makeMKV so perhaps it is not necessary?
#8 Post by Billycar11 » Fri Mar 05, 2021 10:16 am
pmhCH wrote: Fri Mar 05, 2021 9:19 am
it wont work over 1.04 unless it 1.04mk
but not needed unless you use other rippers
