LG BU40N, flashed & can't read 4K UHD (Solved!)
nicholfd
#1 Post by nicholfd » Sat Dec 19, 2020 1:25 am
LG BU40N, UHD Official Internal Slim Sata 9.5mm in a Vantec NST-510S3-BK 9.5mm slim sata case. Connected directly to USB 3.0 port on Mac mini.
Flashed with MK/HL-DT-ST/BU40N-N-Main/HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin from mk-firmware-pack-20200720.zip, using the MakeMKV sdftool from the app
Flash command & output:
/Applications/MakeMKV.app/Contents/MacOS/sdftool -d /IOBDServices/3917BD2D rawflash enc -i Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/BU40N-N-Main/HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
Reading input file Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/BU40N-N-Main/HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.04_212005061142_MZRJ74G1743
yes
 100% Operation finished
Done successfully
Power cycled the drive (disconnected/re-connected USB cable).
Info from the sdftool after the flash:
/Applications/MakeMKV.app/Contents/MacOS/sdftool --d /IOBDServices/3917BD2D --info
SDF.bin version: 0x007B
Drive Tool SDF present
Drive Specific SDF present
[Drive Specific SDF] Embedded Info Strings:
8000:LibreDrive Information
8013:Status
8105:Enabled
8001:Drive platform
:MT1959
8002:Firmware type
8107:Patched (microcode access re-enabled)
8003:Firmware version
:1.04
8005:DVD all regions
8100:Yes
8006:BD raw data read
8100:Yes
8007:BD raw metadata read
8100:Yes
8009:Unrestricted read speed
8100:Yes
[Drive Specific SDF] Embedded Status Message:
8099:Using LibreDrive mode (v%1 id=%2)
:06.2
:FA108BB7DA63
Identification SDF present
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:BU5 :HL-DT-ST:BD-RE BU40N     1.04:NM00500:-
MakeMKV Info:
OS device name: /dev/rdisk3
Product: BD-RE BU40N
Revision: 1.04
Serial number: MZRJ74G1743
Firmware date: 2120-05-06 11:42
Highest AACS version: 76
Firmware version: 1.04
Disc Information
Label: ETUHD_UPK1
Timestamp: 2017-07-06 01:00:58
Data capacity: 55.20 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Drive works fine for DVD & Blu-Ray. Can't seem to read UHD. After 12+ minutes of the drive thrashing around, changing speeds, I get (several more lines of the Scsi error lines than below):
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'IoKit:/IOBDServices/3917BD2D'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'IoKit:/IOBDServices/3917BD2D'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:/IOBDServices/3917BD2D'
Saved AACS dump file as /Volumes/Media/MakeMKV Data/MKB20_v61_E_T_The_Extra-Terrestrial_2A6F.tgz
I can move the disc to a 5 1/4" desktop drive and read it just fine (disc is ok). I've tried multiple 4K UHD Discs. Some screenshots attached.
What am I missing with this drive?!?!?
Thanks,
Frank
Keeps trying...
Keeps trying...
Then a bunch of errors...
And finally failure.
Re: LG BU40N, flashed & can't read 4K UHD
#2 Post by Billycar11 » Sat Dec 19, 2020 1:59 am
try a high powered usb HUB
nicholfd
#3 Post by nicholfd » Sat Dec 19, 2020 3:00 am
Billycar11 wrote: Sat Dec 19, 2020 1:59 am try a high powered usb HUB
Thanks - I'm using a Mac & the USB ports generally offer plenty of power for anything (more than the typical PC). It's showing 900 mA available. I'll find a powered hub, or the "Y" cable that came with the drive chassis and see if that helps.
Thanks,
Frank
900mA available
900mA available
Power available.png (173.99 KiB) Viewed 42257 times
nicholfd
#4 Post by nicholfd » Sat Dec 19, 2020 7:17 pm
I found the Y-USB cable that has two USB-A connectors (came with the drive chassis) - PROBLEM SOLVED! Thanks!
I guess it takes more power to read 4K UHD vs. DVD/Blu-Ray?!?!?! I wonder why?
One more quick question - for future firmwares updates, do I still have to use the "enc" option for encrypted firmware?
Thanks,
Frank
Re: LG BU40N, flashed & can't read 4K UHD (Solved!)
#5 Post by SamuriHL » Sat Dec 19, 2020 7:59 pm
There are NO future firmware updates!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Touch not thy drive lest ye find yourself crying. Leave it right where it is.
pmhCH
#6 Post by pmhCH » Thu Mar 04, 2021 7:55 pm
I cannot seem to make the sdftool to work - tried the same syntax as you but I only get:
-bash: sdftool: command not found
What is wrong? Do you have perhaps a 101-instruction? ;) Or is there an interface in the meantime to flash with MacOS?
Here the drive info:
Found 1 drives(s)
00: /IOBDServices/11B1380F
HL-DT-ST_BD-RE_BU40N_1.01_211910161032_MO5KCTF2216
Samsung 78" (still with 3D), ATV 4k (64Gb) running Infuse, Hue Sync + Sonos "5.1"
nicholfd
#7 Post by nicholfd » Thu Mar 04, 2021 8:09 pm
pmhCH wrote: Thu Mar 04, 2021 7:55 pm I cannot seem to make the sdftool to work - tried the same syntax as you but I only get:
You need to provide the full command line you attempted to use. You probably left the path off the command line. Where is the sdftool located (on a Mac, it's normally in the MakeMKV app, located in /Applications)? Where do you have MakeMKV installed? What is your current directory (type `pwd` to find out)?
pmhCH
#8 Post by pmhCH » Thu Mar 04, 2021 8:19 pm
nicholfd wrote: Thu Mar 04, 2021 8:09 pm
Pierre-Maries-MacBook-Pro:MacOS pmheller$ pwd
Pierre-Maries-MacBook-Pro:MacOS pmheller$ ls
libdriveio.dylib libmqt.dylib sdf.bin
libfdk.dylib makemkv sdftool
libffm.dylib makemkvcon
libmakemkv.dylib mmccextr
I have the HL-DT-ST folder in Downloads
nicholfd
#9 Post by nicholfd » Thu Mar 04, 2021 8:21 pm
pmhCH wrote: Thu Mar 04, 2021 8:19 pm
You forgot to include the command line you used to try & flash the drive. Copy/paste what you typed into the terminal when you tried to flash the drive. You probably left off a "./" at the beginning, which indicates the sdftool is in your current directory.
pmhCH
#10 Post by pmhCH » Thu Mar 04, 2021 8:24 pm
nicholfd wrote: Thu Mar 04, 2021 8:21 pm
Just to make sure:
My drive is following:
Pierre-Maries-MacBook-Pro:MacOS pmheller$ ./makemkvcon f --list
Found 1 drives(s)
I have the HT-DT-ST folder in "Downloads"
So which syntax is correct being in the folder I am now?
nicholfd
#11 Post by nicholfd » Thu Mar 04, 2021 8:27 pm
pmhCH wrote: Thu Mar 04, 2021 8:24 pm
Just to make sure:
Found 1 drives(s)
If you stay in the directory you showed above, inside the MakeMKV app, you would start the command line with `./sdftool ` and add the rest of the command line options for your drive.
pmhCH
#12 Post by pmhCH » Thu Mar 04, 2021 8:30 pm
nicholfd wrote: Thu Mar 04, 2021 8:27 pm
Just to make sure:
Found 1 drives(s)
Hmm... now I'm not sure which file to choose as I probably should downgrade from 1.01 to 1.00 - there seems not to be any 1.00 binary...
Any ideas?
nicholfd
#13 Post by nicholfd » Thu Mar 04, 2021 8:34 pm
pmhCH wrote: Thu Mar 04, 2021 8:30 pm
Just to make sure:
Found 1 drives(s)
Any ideas?
Not me - my knowledge comes from others in this forum, who are much more knowledgable. Maybe search for another thread with your drive, or start a new thread and specifically ask what firmware for your drive.
