Fatale
hvnphoto
Fatale
Post by hvnphoto » Mon Feb 22, 2021 2:42 am
US Retail
Title information
Source file name: 00900.mpls
Duration: 1:42:35
Chapters count: 16
Segment count: 15
Segment map: 514,510,503,509,504,505,507,501,513,512,502,511,515,506,508
File name: Fatale_t138.mkv
swervarelli
Re: Fatale
Post by swervarelli » Wed Mar 03, 2021 12:47 am
Would this happen to be the redbox version?
hytech1956
Re: Fatale
Post by hytech1956 » Wed Mar 03, 2021 11:37 pm
Any info for the Redbox version?
PrideOfPR7
Re: Fatale
Post by PrideOfPR7 » Thu Mar 04, 2021 1:09 am
hvnphoto wrote: Mon Feb 22, 2021 2:42 am US Retail
Title information
Duration: 1:42:35
Chapters count: 16
Segment count: 15
Confirmed that this is the same on RB. ProcMon verified:
G:\BDMV\STREAM\00514.m2ts SUCCESS
G:\BDMV\STREAM\00510.m2ts SUCCESS
G:\BDMV\STREAM\00503.m2ts SUCCESS
G:\BDMV\STREAM\00509.m2ts SUCCESS
G:\BDMV\STREAM\00504.m2ts SUCCESS
G:\BDMV\STREAM\00505.m2ts SUCCESS
G:\BDMV\STREAM\00507.m2ts SUCCESS
G:\BDMV\STREAM\00501.m2ts SUCCESS
G:\BDMV\STREAM\00513.m2ts SUCCESS
G:\BDMV\STREAM\00512.m2ts SUCCESS
G:\BDMV\STREAM\00502.m2ts SUCCESS
G:\BDMV\STREAM\00511.m2ts SUCCESS
G:\BDMV\STREAM\00515.m2ts SUCCESS
G:\BDMV\STREAM\00506.m2ts SUCCESS
G:\BDMV\STREAM\00508.m2ts SUCCESS
Balderdash!
Re: Fatale
Post by Balderdash! » Thu Mar 04, 2021 2:01 am
The RB version does not contain the file "Fatale_t138.mkv".
hytech1956
Re: Fatale
Post by hytech1956 » Thu Mar 04, 2021 10:55 am
Thanks so much for your help!!
mmmzon
Re: Fatale
Post by mmmzon » Thu Mar 04, 2021 1:35 pm
Confirmed 00900.mpls for RB version picked up yesterday.
Re: Fatale
Post by Woodstock » Thu Mar 04, 2021 1:50 pm
File name depends on your minimum title length - titles smaller than that aren't counted.
Balderdash!
Re: Fatale
Post by Balderdash! » Thu Mar 04, 2021 2:07 pm
Hey, thanks for the clarification.
bonerb1981
Re: Fatale
Post by bonerb1981 » Sun Mar 07, 2021 10:03 pm
I have 4 different tracks on the DVD RB version of this movie. how do you figure out which it is?
LG-BDNU40
Re: Fatale
Post by LG-BDNU40 » Sun Mar 14, 2021 12:11 am
Second 00900.mpls Fatale_t187.mkv
Title information
Duration: 1:42:35
Chapters count: 16
Segment count: 15
File name: Fatale_t187.mkv for my version of RB
preserve
Re: Fatale
Post by preserve » Sun Mar 14, 2021 9:37 am
LG-BDNU40 wrote: Sun Mar 14, 2021 12:11 amFile name: Fatale_t187.mkv for my version of RB
Just to clarify, the "t" "title" number in the filename is an arbitrary number that MakeMKV assigns based on the order that it loads the content of the disc, which can be affected by factors such as minimum title length as mentioned above.
What you should look at when finding, sharing, or confirming the correct file is what MakeMKV labels as the source file name, generally an mpls playlist number, and commonly referred to as just a playlist:
LG-BDNU40 wrote: Sun Mar 14, 2021 12:11 amSource file name: 00900.mpls
You can also add this "source" number, which will either be an mpls playlist or an m2ts file, to the filenames that MakeMKV creates by going into your preferences and changing the "Default Output File Name Template" to include "{_s:SN}"
Using: ASUS BW-16D1HT 3.00
