Fatale
hvnphoto
Fatale
Post by hvnphoto »
US Retail
Title information
Source file name: 00900.mpls
Duration: 1:42:35
Chapters count: 16
Segment count: 15
Segment map: 514,510,503,509,504,505,507,501,513,512,502,511,515,506,508
File name: Fatale_t138.mkv
swervarelli
Re: Fatale
Post by swervarelli »
Would this happen to be the redbox version?
hytech1956
Re: Fatale
Post by hytech1956 »
Any info for the Redbox version?
PrideOfPR7
Re: Fatale
Post by PrideOfPR7 »
hvnphoto wrote:
Mon Feb 22, 2021 2:42 am
US Retail
Title information
Duration: 1:42:35
Chapters count: 16
Segment count: 15
Confirmed that this is the same on RB. ProcMon verified:
G:\BDMV\STREAM\00514.m2ts SUCCESS
G:\BDMV\STREAM\00510.m2ts SUCCESS
G:\BDMV\STREAM\00503.m2ts SUCCESS
G:\BDMV\STREAM\00509.m2ts SUCCESS
G:\BDMV\STREAM\00504.m2ts SUCCESS
G:\BDMV\STREAM\00505.m2ts SUCCESS
G:\BDMV\STREAM\00507.m2ts SUCCESS
G:\BDMV\STREAM\00501.m2ts SUCCESS
G:\BDMV\STREAM\00513.m2ts SUCCESS
G:\BDMV\STREAM\00512.m2ts SUCCESS
G:\BDMV\STREAM\00502.m2ts SUCCESS
G:\BDMV\STREAM\00511.m2ts SUCCESS
G:\BDMV\STREAM\00515.m2ts SUCCESS
G:\BDMV\STREAM\00506.m2ts SUCCESS
G:\BDMV\STREAM\00508.m2ts SUCCESS
Balderdash!
Re: Fatale
Post by Balderdash! »
The RB version does not contain the file "Fatale_t138.mkv".
hytech1956
Re: Fatale
Thanks so much for your help!!
mmmzon
Re: Fatale
Post by mmmzon »
Confirmed 00900.mpls for RB version picked up yesterday.
Re: Fatale
File name depends on your minimum title length - titles smaller than that aren't counted.
Balderdash!
Re: Fatale
Hey, thanks for the clarification.
bonerb1981
Re: Fatale
Post by bonerb1981 »
I have 4 different tracks on the DVD RB version of this movie. how do you figure out which it is?
LG-BDNU40
Re: Fatale
Post by LG-BDNU40 »
Second 00900.mpls Fatale_t187.mkv
Title information
Duration: 1:42:35
Chapters count: 16
Segment count: 15
File name: Fatale_t187.mkv for my version of RB
preserve
Re: Fatale
Post by preserve »
LG-BDNU40 wrote:
Sun Mar 14, 2021 12:11 am
Just to clarify, the "t" "title" number in the filename is an arbitrary number that MakeMKV assigns based on the order that it loads the content of the disc, which can be affected by factors such as minimum title length as mentioned above.
What you should look at when finding, sharing, or confirming the correct file is what MakeMKV labels as the source file name, generally an mpls playlist number, and commonly referred to as just a playlist:
You can also add this "source" number, which will either be an mpls playlist or an m2ts file, to the filenames that MakeMKV creates by going into your preferences and changing the "Default Output File Name Template" to include "{_s:SN}"
Using: ASUS BW-16D1HT 3.00
