Multiple titles for single movie?
HairyScot
Post by HairyScot »
When I ran MakeMKV on Star Wars II - Attack of the Clones it produced two MKV files of 3.9GB, according to the title list one was Angle 1 the other Angle 2 but I can see no discernible differences when viewing them.
Anyone have an answer on that one?
I then tried MakeMKV with a BlueRay ISO of Constantine which is about 27GB.
This produced about 20 MKV files, 3 of 11GB which look to be copies of the complete movie (have the same content), and 17 others which appear to be scenes or specials.
Any info would be appreciated.
setarip_old
Re: Multiple titles for single movie?
Post by setarip_old »
Hi!
How about the opening scroll? ;>}
HairyScot
Post by HairyScot »
setarip_old wrote:Hi!
Not sure what you mean. Can you expand on that please?
setarip_old
You say you see no discernible difference between the two. I take that to mean you've made an .MKV of each. You should be seeing the opening scroll in differing languages for each .MKV (English for one and, IIRC, Spanish for the other)...
Long ago, in a galaxy far, far away
HairyScot
Post by HairyScot »
setarip_old wrote:You say you see no discernible difference between the two. I take that to mean you've made an .MKV of each. You should be seeing the opening scroll in differing languages for each .MKV (English for one and, IIRC, Spanish for the other)...
Yes! Gottit!
Do you think same type of thing might have happened with the BlueRay?
setarip_old
Yes...
