NiCE77
#4561 Post by NiCE77 » Sun Feb 28, 2021 8:37 am
bobbymkV wrote: Sat Feb 27, 2021 5:14 pm
NiCE77 wrote:
DaMacFunkin wrote: Fri Feb 26, 2021 6:06 am So I have the Chinoppo, 2 Shield 2019 Pro, 4K firestick, Zidoo Z9X, had the Google thing with the long name and sold it because it can’t do lossless audio, what do I buy next, is this Ugog a winner?
I have the Shield 2019 Pro, FireTV 4k Stick, Zidoo Z9X, Apple TV 4K, Minix U22-XJ, X96 Max+ with CoreELEC and the Ugoos AM6 Plus :D
For DV FEL, the Ugoos is the best choice.
Has it been confirmed that the FEL is actually being used with the Ugoos? Picture comparisons somewhere?
Here: https://www.avsforum.com/threads/media- ... r.3183512/
shawnc22 wrote: Sat Feb 27, 2021 5:18 pm Ah it looks the v0.3.7 is the latest firmware that was ported over, is this enough for FEL playback or do you need one of the newer ones? And have you tried it yourself? Only reason I’m asking is because the minix looks Iike it’s much easier to get here in the states :D
Yes, I'm tried, it works.
DaMacFunkin wrote: Sat Feb 27, 2021 6:02 pm So, STDL playback is only stable in Plex on Ugoos, but only Kodi will do HD audio?
Yes. But in kodi they will definitely be improved.
mattmarsden wrote: Sat Feb 27, 2021 6:28 pm Whats your workflow for creating STDL ts files? Do you go via Makemkv?
No, demux with tsmuxer -> making stdl hevc with yusesope's tool -> remux with dolby's mp4muxer -> remux to ts with tsmuxer
It might work like this: demux with tsmuxer -> making stdl hevc with yusesope's tool -> remux hevc to ts with tsmuxer
DaMacFunkin
#4562 Post by DaMacFunkin » Sun Feb 28, 2021 5:05 pm
NiCE77 wrote: Sun Feb 28, 2021 8:37 am
So over on the Kodi thread Fandangos isn’t aware how it is working and seem to believe that Ugoos have their own fork.
Do Ugoos have their own fork?
Or is going to be the case that Fandangos or someone else will need to get the Ugoos and refine the current process?
mattmarsden
#4563 Post by mattmarsden » Sun Feb 28, 2021 5:13 pm
No the Ugoos is using the Kodi DV build that is being geared for the Shield so it will need refining further, but worth it I think as its the only device that will do FEL with HD audio.
#4564 Post by shawnc22 » Sun Feb 28, 2021 5:49 pm
The Ugoos has no problem with HD audio at the moment when you launch Kodi out of Android? Last I heard the amlogic soc had some sort of issue where you can only get HD audio out of CoreELEC Kodi.
mattmarsden
#4565 Post by mattmarsden » Sun Feb 28, 2021 6:10 pm
No, HD audio works perfectly with Android Kodi on the Ugoos.
ragico
#4566 Post by ragico » Sun Feb 28, 2021 6:26 pm
shawnc22 wrote: Sun Feb 28, 2021 5:49 pm The Ugoos has no problem with HD audio at the moment when you launch Kodi out of Android? Last I heard the amlogic soc had some sort of issue where you can only get HD audio out of CoreELEC Kodi.
yes, confirm HD audio works in Kodi.
#4567 Post by shawnc22 » Sun Feb 28, 2021 7:43 pm
ragico wrote: Sun Feb 28, 2021 6:26 pm
nice! that's definitely promising. hopefully @RESET_9999 or @Manixx can get their hands on one soon to do some in depth comparisons :)
XTrojan
#4568 Post by XTrojan » Mon Mar 01, 2021 3:55 am
Is it just Ugoos who utilize the newest AmLogic chipset that can perfect Dolby Vision decoding with FEL? (Ignoring Blu-Ray players)
XTrojan
#4569 Post by XTrojan » Mon Mar 01, 2021 3:56 am
NiCE77 wrote: Sat Feb 27, 2021 8:50 am
Why just "DV FEL", does the Ugoos have any issues with other media formats outside of DV FEL? Just curious since i'm looking for a MP that playbacks most things with as good quality as possible.
NiCE77
#4570 Post by NiCE77 » Mon Mar 01, 2021 7:34 am
XTrojan wrote: Mon Mar 01, 2021 3:56 am
The Ugoos as all Amlogic, only with CoreELEC is perfect for media playback. You can use with dual boot. DV playback is not working with CoreELEC now, because no 64 bit dovi.ko module.
mattmarsden
#4571 Post by mattmarsden » Mon Mar 01, 2021 7:49 am
Anroid Kodi 19 DV build seems to play all my other media including DV MEL mkv perfectly so just needs the FEL sorting and then in my opinion its perfect.
XTrojan
#4572 Post by XTrojan » Mon Mar 01, 2021 5:37 pm
mattmarsden wrote: Mon Mar 01, 2021 7:49 am
Is FEL even confirmed in upcoming Kodi 19 updates though? Kind of annoying that one would need to switch constantly. Also I noticed that the Ugoos is not in my country, but the Minix NEO U22-XJ is which uses the same chipset as the Ugoos, anyone can confirm if the Minix is able to do flawless DV with FEL?
mattmarsden
#4573 Post by mattmarsden » Tue Mar 02, 2021 8:03 am
You don't need to switch, just use the Android Kodi 19 DV build to play everything - it works fine. I've actually got a Minix U22 sitting in front of me that I'm going to test today so I'll let you know shortly how well it works.
mattmarsden
#4574 Post by mattmarsden » Tue Mar 02, 2021 8:04 am
I've also noticed if you completley quit Kodi and and restart it and play a FEL mkv straight away they play a lot better. Hopefully the build will be refined soon.
mattmarsden
#4575 Post by mattmarsden » Tue Mar 02, 2021 11:12 am
OK, Minix U22 on latest firmware does not work properly with the Kodi DV build, it will only allows selection of resolution 1920x1080p 60hz. I believe it can be flashed with the Ugoos firmware but I havn't tried that.
