MakeMKV drops non-empty audio tracks?
archiveEverything
Post by archiveEverything » Fri Feb 26, 2021 2:14 pm
I have a DVD that seems to use the Blu-Ray strategy of using different titles to select alternate audio tracks in the same underlying video stream.
As a result, MakeMKV exports each title with only a single audio track, rather than all the audio tracks originally present in the video stream. Expanding the dropdown for each title also shows only a single audio track, so I presume MakeMKV is making its decision based on the title data, rather than on the stream.
Of course, I don't really want two separate, full-size MKVs. I'd much rather have a single MKV with both audio tracks in it.
Is there any way to export all of the audio tracks in an A/V stream when the title only lists one of them?
archiveEverything
Re: MakeMKV drops non-empty audio tracks?
Post by archiveEverything » Sat Feb 27, 2021 6:04 pm
By way of update, this loss of audio tracks also happens on 1.16.0.
Post by dcoke22 » Sat Feb 27, 2021 10:07 pm
The MKVToolNix set of tools will probably let you mash the two audio tracks into a single .mkv file. It isn't a thing I've ever needed to do, so I'm just making an informed guess.
Post by Woodstock » Sun Feb 28, 2021 12:43 am
It comes down to how the disk is mastered - the only work around I have found for it is to rip both, and use MKVmerge to create a new MKV file with the combined audio and subtitle tracks.
I've only had to do it for BD releases, though.
archiveEverything
Post by archiveEverything » Wed Mar 03, 2021 6:44 pm
Thanks for the response. It sounds this is just part of how MakeMKV views the world.
Converting a VOB (or m2ts) to mkv via ffmpeg preserves all the tracks in the underlying stream, so I wasn't sure if it was intentional behavior by MakeMKV.
I do wish MakeMKV would at least list all the audio tracks, and only select by default the tracks chosen/available by the title. As it stands now, I can't completely trust what MakeMKV shows me.
