HarperVision
Post by HarperVision » Thu Feb 25, 2021 1:38 am
RESET_9999 wrote:
HarperVision wrote: Wed Feb 24, 2021 10:35 pm What is the fastest method?
So what exactly is muxing doing? If I rip my movie using DVDFab I can play it in that format already, so why mux it?
How do I know what track to keep after dragging and dropping the largest file (or playlist)? Which and why am I choosing it?
This is what I’m talking about. Every answer I see on these corresponding threads are always so short and abbreviated, assuming the reader just knows everything involved already. It seems nobody ever makes a post with step by step instructions with clear and concise answers as to why and what you’re doing. That’s how I learn anyway.
Either way, thanks a ton for helping me get there! Image
DVDFAB can't remux DV with Atmos and it's remuxing into a mp4 container which is a bit buggy on the x700/x800m2.
This is why you need to use tsMuxer which (just like DVDFAB) makes the file playable in DV (TS or M2TS container). tsMuxer also supports Atmos (or any lossless audio).
The tracks you keep are:
1- the 1st HEVC stream (HDR10 base layer)
2- the 2nd HEVC stream (DV layer)
3- any audio you want (you can add external audio)
4- any subtitles you want.(you can add external subs)
Sweet, so incredibly awesome, thanks! Good thing is, that’s exactly how I did it but of course when I tried it in Infuse on AppleTV it didn’t show DV, so I moved on and eventually used DVDFAB’s .mp4, but lost Atmos.
Navigating and lack of a polished GUI with cover/poster art on the X800M2 kinda sucks though. Is there no solution to get LLDV DV, ATMOS and bit perfect quality with a nice GUI poster wall?
NiCE77
Post by NiCE77 » Thu Feb 25, 2021 6:22 am
mattmarsden wrote: Wed Feb 24, 2021 2:54 pm I've tried with Kodi final build and it plays OK but a bit stuttery and often doesn't work after seeking. Plex doesn't seem to work at all with them for me. Interesting about the 2 hardware decoders - where did you see that?
On S922X datasheet:
- Support multi-video decoder up to 4Kx2K@60fps+1x1080P@60fps
mattmarsden
Post by mattmarsden » Thu Feb 25, 2021 5:38 pm
HarperVision wrote: Thu Feb 25, 2021 1:38 am
Ugoos AM6 plus with Kodi 19 DV build, mux to mkv.
mattmarsden
Post by mattmarsden » Thu Feb 25, 2021 5:39 pm
mattmarsden wrote: Thu Feb 25, 2021 5:38 pm
Ugoos AM6 plus with Kodi 19 DV build, mux to mkv. LLDV can be enabled with all content.
mattmarsden
Post by mattmarsden » Thu Feb 25, 2021 5:48 pm
NiCE77 wrote: Thu Feb 25, 2021 6:22 am
On S922X datasheet:
Out of interest what firmware version are you running on the Ugoos?
Romero91
Post by Romero91 » Thu Feb 25, 2021 7:43 pm
Dune HD Pro Vision 4K Solo vs Chinoppo - Dolby Vision FEL Test file
I don't know if the Dune processes the FEL layer correctly or not, but the file plays smoothly. The TV displays the Dolby Vision logo and it's a sharper image (Less noise).
Chinoppo (M9201) Dolby Vision FEL Test file
Dune HD Pro Vision 4K Solo Dolby Vision FEL Test file
mattmarsden
Post by mattmarsden » Thu Feb 25, 2021 8:31 pm
Its not processing the FEL and the Chinoppo won’t do DV on those test files - has to be a dual layer m2ts or iso.
Romero91
Post by Romero91 » Thu Feb 25, 2021 8:40 pm
mattmarsden wrote: Thu Feb 25, 2021 8:31 pm Its not processing the FEL and the Chinoppo won’t do DV on those test files - has to be a dual layer m2ts or iso.
This demo comes from this FullBD FEL Test: https://onedrive.live.com/?cid=938b847d ... NKSMP1Pl-Q
Post by RESET_9999 » Thu Feb 25, 2021 10:27 pm
Romero91 wrote: Thu Feb 25, 2021 7:43 pm
mmm, I guess you didn't read my post about the Dune FEL ISO playback comparisons @manix and I did.
The Dune does not support FEL at all and likely never will. yes, it can play the file, but it's using only the RPU metadata.
mattmarsden wrote: Thu Feb 25, 2021 8:31 pm the Chinoppo won’t do DV on those test files - has to be a dual layer m2ts or iso.
what? the test file is dual-layer DV mp4 which the oppo support.
mattmarsden
Post by mattmarsden » Thu Feb 25, 2021 10:44 pm
Pretty sure it only supports Profile 5 single layer mp4.
Post by RESET_9999 » Thu Feb 25, 2021 10:47 pm
mattmarsden wrote: Thu Feb 25, 2021 10:44 pm Pretty sure it only supports Profile 5 single layer mp4.
the oppo support all the profiles/containers (except mkv) just like the x700/x800m2...
dual-layer DV in an mp4 or ts or m2ts container is all the same.
Romero91
Post by Romero91 » Thu Feb 25, 2021 10:51 pm
Dune's FW changelog then lie? :(
is there a real noticeable difference between the P7 FEL and the DVS10 Engine? (RPU metadata only)?
If you see my comparison, I see the Dune with better image than the chinoppo with FEL supported at 100%.
On the other way, if the FEL layer is not really taken into account by the Dune, even if it reproduces it ..
my TV is an LG OLED, compatible with FEL, in principle? If I select "Dolby Vision Output Mode" in "tv-led", would the benefit of the FEL layer from Dune to LG OLED?
Or if i connect the Dune HDMI OUT to chinoppo HDMI, So if it would process the FEL layer?
Thanks for your time.
RESET_9999 wrote: Thu Feb 25, 2021 10:27 pm
mattmarsden
Post by mattmarsden » Thu Feb 25, 2021 10:53 pm
RESET_9999 wrote: Thu Feb 25, 2021 10:47 pm
Pretty sure it doesnt in mp4 which is why that photo from the Chinoppo isn’t showing the FEL noise, but I don’t have anyone and can’t 100% remember.
Post by RESET_9999 » Thu Feb 25, 2021 11:02 pm
Romero91 wrote: Thu Feb 25, 2021 10:51 pm Dune's FW changelog then lie? :(
yes, they are lying.
see here https://slow.pics/c/nCcd2BlK
this is Dune FEL dual-layer p7 VS Dune single-layer P8 (rpu only) VS Sony x700 FEL dual layer p7 VS HDR10 bluray remux.
As you can see there's no difference between p8 and p7 on the Dune player and the x700 shows what FEL can bring.
about your comparison: The FEL sample file is supposed to be noisy when FEL is processed, that's the whole point of the file. The dune is clean because it's not using the FEL.
and yes, your TV can do FEL if the external player can do FEL. No matter the settings you use, you'll never get FEL out of the Dune.
Post by RESET_9999 » Thu Feb 25, 2021 11:05 pm
mattmarsden wrote: Thu Feb 25, 2021 10:53 pm Pretty sure it doesnt in mp4 which is why that photo from the Chinoppo isn’t showing the FEL noise, but I don’t have anyone and can’t 100% remember.
Well, I'm seeing noise on the oppo picture compared to the dune picture.
I don't see why the oppo wouldn't support dual layer DV in an MP4 container... for DV, its not different than a TS or M2TS container
I don't have one, so maybe someone that owns one can confirm.
