yossSP
Post by yossSP »
Manixx2020beyound wrote: Mon Feb 22, 2021 7:27 pm D0F9086A-5B9B-4773-9F0F-A17459BA04ED.jpeg
RESET_9999 wrote: Mon Feb 22, 2021 5:10 pm
yossSP wrote: Mon Feb 22, 2021 3:31 pm
One more question. Could it be possible that in february firmware (or future update) Google updated the new Chromecast to permit TV-LED playback?
Manix will be able to verify that.
the colors as well.
It’s here & it’s a solid build heavy too
Size compared to a mac m1 mini
Fingers crossed on Fel lol
Nice to see you Manixx :)
One more data about Dolby Vision processing of Chromecast with GoogleTV, Vincents says that during a TV-LED playback Dolby Vision IQ can't use the light sensor of the TV, so I tested it again and with my Panasonic HX1000 the sensor is regulating brightness on the image.
@Manixx2020beyound finally got his hands on the new Dune player, time to do some comparisons :)
Unfortunately, the Dune does like the Shield and ignores the EL but there is no red push and the colors seem to be accurate. Even though it looks like the dune is ignoring the EL, there is still an improvement compared to the base layer. We have to compare it with a P8 rip.
Of course, this is an extreme case and it wouldn't be so different if the studios encoded the base layer properly in the first place but the improvement that the FEL brings here is phenomenal, imaging when we'll have true 12bit TV.
DV captured in PQ with the latest Atomos Shogun.
2160p comparisons
tonemapped to SDR comparisons ( madVR static 300nits):
Dune FEL DV ISO vs X700 FEL DV: https://screenshotcomparison.com/comparison/11367
Dune FEL DV ISO vs HDR10 bluray remux:https://screenshotcomparison.com/comparison/11365
X700 FEL DV vs HDR10 bluray remux: https://screenshotcomparison.com/comparison/11366
1080p comparisons
Dune FEL DV ISO vs X700 FEL DV: https://screenshotcomparison.com/comparison/11372
Dune FEL DV ISO vs HDR10 bluray remux: https://screenshotcomparison.com/comparison/11374
X700 FEL DV vs HDR10 bluray remux: https://screenshotcomparison.com/comparison/11375
Dune FEL vs Dune P8 vs X700 FEL vs HDR10 bluray remux: https://slow.pics/c/nCcd2BlK
untouched PQ images from the Shogun:
https://drive.google.com/file/d/16HOh1R ... sp=sharing,
https://drive.google.com/file/d/17-XW-E ... sp=sharing
https://drive.google.com/file/d/18qNpoU ... sp=sharing
interesting, the size difference of the lossless png...
I uploaded samples in different container and profile of that scene:
https://drive.google.com/file/d/11fzJYb ... sp=sharing,
https://drive.google.com/file/d/1LtE3ju ... sp=sharing,
https://drive.google.com/file/d/1jrDF5j ... sp=sharing,
https://drive.google.com/file/d/1mYy3WO ... sp=sharing,
https://drive.google.com/file/d/1nD7-MH ... sp=sharing,
https://drive.google.com/file/d/1on9KfI ... sp=sharing,
https://drive.google.com/file/d/1xJkiL0 ... sp=sharing
yossSP
Post by yossSP »
RESET_9999 wrote: Tue Feb 23, 2021 1:36 am @Manixx2020beyound finally got his hands on the new Dune player, time to do some comparisons :)
2160p comparisons
1080p comparisons
Wow! thanks a lot for this battery of samples @RESET_9999 :)
And thanks also to @Manixx2020beyound for this comparison work.
I'll try later with this .mkv and tell how do it the Chromecast.
dysprosium
Post by dysprosium »
Thanks for the comparisons; unfortunate to see that the EL is ignored again. It would be great to get the same FEL/colour accuracy comparisons on the Ugoos AM6 Plus and the Chromecast with Google TV if possible, now that there are some reports that they properly decode FEL.
NiCE77
Post by NiCE77 »
2160p comparisons
1080p comparisons
Thanks! Interesting, the image of the Dune is much less detailed.
yossSP
Post by yossSP »
2160p comparisons
1080p comparisons
Damn it... only Total.Recall.1990.SL-P8-MEL.mkv file enable Dolby Vision with my Chromecast with Google TV, every other file plays in HDR10.
I tried to create a mkv file via MakeMKV from the .iso, but it does the same. So I can't test the FEL processing...
The other samples worked well and other DV FEL files also do it fine, but not these ones... anyone can contribute with a solution?
Thanks in any case :)
HarperVision
Post by HarperVision »
shawnc22 wrote:
HarperVision wrote: Tue Feb 02, 2021 7:56 pm Yes that can be tricky so I always make sure I check the HDfury web GUI to see what is being sent. I’m the one who discovered the HDFury LLDV/Dolby Vision hack for HDR only displays/projectors and shared it with the world, so I know this well and check It often.
So the answer is, Infuse Pro only plays the HDR base layer of the DV rip so I’m only getting HDR10 and no DV, correct?
I do like the results of it with Dolby Vision forced on with Match Dynamic Range set to off. The AppleTV 4K does an exemplary job of mapping it to pseudo Dolby Vision but I’d love to feed it real DV if at all possible of course!
Unfortunately like the previous poster said, you're never going to get real DV from UHD rips on an AppleTV. The main issue is that the hardware is only capable of profile 5 DV, which is single layer and in a different color space from the profile 7 found on UHD disks. So even if you have an MEL title that you can safely convert to single layer, you're still likely to have color accuracy issues to the lack of a color space conversion between the different profiles. With tsMuxer, you can alter the source code (there are also compiled versions floating around) so that instead of spitting out profile 8 for single layer files, it would produce profile 5 files. People have used this for their ATV, but like I said, there are likely to be color issues.
I have ripped the movie The Meg to .mp4 DV single layer using DVDFab and it shows up as DV in the Infuse GUI and plays as such just fine. The colors seem the same as when I play the disc in my Sony X800M2. I’m an ISF Certified Calibrator amongst many other industry things for 30+ years so would notice if color was amiss. What color issue is it that I’m supposed to be looking for exactly?
The only reason I’m not satisfied at this point is due to the lack of ATMOS audio.
So am I reading right that the new Chromecast Google TV is capable of playing all DV profiles with MEL and FEL and ATMOS?
mattmarsden
Post by mattmarsden »
Thinking of going for an Oppo 203 for DV - does anyone know if the issue of the green garbled screen after playing a DV m2ts has been solved?
Post by Manixx2020beyound »
Dune tvled from m2ts
2160p comparisons
1080p comparisons
Dune tv led is different/ compare to their version of LLDV but there is know way to really prove that
Testing ghost in a shell
iSO which has a 8gg FEl
Curious on a more morden revision
So would the diff here be even more obvious?
Being that the fel is 8gigs ?
Also there seems to be more grain on different settings on the dune so more test is needed diff Fels
Last edited by Manixx2020beyound on Tue Feb 23, 2021 6:23 pm, edited 2 times in total.
dysprosium wrote: Tue Feb 23, 2021 4:41 am Thanks for the comparisons; unfortunate to see that the EL is ignored again. It would be great to get the same FEL/colour accuracy comparisons on the Ugoos AM6 Plus and the Chromecast with Google TV if possible, now that there are some reports that they properly decode FEL.
Manix should be able to test the Chromecast as well. He doesn't own the Ugoos.
yossSP wrote: Tue Feb 23, 2021 8:45 am Damn it... only Total.Recall.1990.SL-P8-MEL.mkv file enable Dolby Vision with my Chromecast with Google TV, every other file plays in HDR10.
yeah, it's probably because of the splitting...
FFmpeg gives me some warning when I try to demux the splitted layers.
HarperVision wrote: Tue Feb 23, 2021 10:07 am I have ripped the movie The Meg to .mp4 DV single layer using DVDFab and it shows up as DV in the Infuse GUI and plays as such just fine. The colors seem the same as when I play the disc in my Sony X800M2. I’m an ISF Certified Calibrator amongst many other industry things for 30+ years so would notice if color was amiss. What color issue is it that I’m supposed to be looking for exactly?
Since you have the x800m2, why don't you just remux your bluray with tsmuxer and play them via USB ?
Even if profile 5 with HDR10 base layer ''could'' be looking right, you're missing the EL.
mattmarsden wrote: Tue Feb 23, 2021 12:51 pm Thinking of going for an Oppo 203 for DV - does anyone know if the issue of the green garbled screen after playing a DV m2ts has been solved?
not fixed, it's a tsmuxer bug. But the oppo can play ISO without the bug, so just use that format.
yossSP
Post by yossSP »
No every Atmos...
I can confirm that the new Chromecast with Google TV supports:
Video:
HDR
HDR10
HDR10+
HLG
Dolby Vision Single Track Double Layer in P4, P5, P7 MEL/FEL, P8 profiles
Audio
Dolby Digital (AC3)
Dolby Digital Plus (EAC3)
Dolby Digital Plus + Dolby Atmos
DTS (only with Kodi)
DTS-ES Discrete/Matrix (only with Kodi)
AAC
PCM multichannel (only with Kodi)
Audio not supported:
Dolby TrueHD
Dolby TrueHD + Dolby Atmos
DTS-HD
DTS-X
I don't have an Atmos ready AVR so I can't test too much, I don't know if it could be possible to convert the TrueHD stream to lossless MCPCM or EAC3 and maintain the Atmos layer.
About DV profile 7 FEL I'm now making some tests to determine if it's processing the FEL layer in the right way, but teh first test is passed.
Stay connected...
mattmarsden
[/quote]
Problem is the Oppo doesn't resume play with ISO but it does with m2ts so would really like to use that.
mattmarsden wrote: Tue Feb 23, 2021 3:39 pm Problem is the Oppo doesn't resume play with ISO but it does with m2ts so would really like to use that.
then, just do not watch two movies in a row :) (or use the file in my signature to unlock the player)
I have the x700 and the bug doesn't really annoy me.
daddy
Post by daddy »
yossSP wrote: Tue Feb 23, 2021 3:20 pm About DV profile 7 FEL I'm now making some tests to determine if it's processing the FEL layer in the right way, but teh first test is passed.
Can you explain us how, from 2 differents tracks (one hdr10 4k track and one DV 2k track with metadata), you are obtaining a unique track with metadada ?
shawnc22 wrote: Unfortunately like the previous poster said, you're never going to get real DV from UHD rips on an AppleTV. The main issue is that the hardware is only capable of profile 5 DV, which is single layer and in a different color space from the profile 7 found on UHD disks. So even if you have an MEL title that you can safely convert to single layer, you're still likely to have color accuracy issues to the lack of a color space conversion between the different profiles. With tsMuxer, you can alter the source code (there are also compiled versions floating around) so that instead of spitting out profile 8 for single layer files, it would produce profile 5 files. People have used this for their ATV, but like I said, there are likely to be color issues.
No every Atmos...
Video:
HDR
HDR10
HDR10+
HLG
Audio
Dolby Digital (AC3)
AAC
Dolby TrueHD
DTS-HD
DTS-X
Stay connected...
On my setup chrome cast gave me to most issues, bc off my vertex2,
P8 plays for me but only a few minutes.
But directly into the tv works better.
& plex is the only way on Chromecast?
P5 plays fine of course.
Chromecast cast feel like the vs10 engine
LLDV on it clashes with LLDV on the vertex2
When I use my amplifier u see 24bit 422 yuv as well without the vertex2 another answer that’s it’s LLDV only. Also no forced dv8 rgb from the vertex with that device
Vs10 engine is LLDV from what the vertex is showing
Last edited by Manixx2020beyound on Tue Feb 23, 2021 6:21 pm, edited 2 times in total.
