Ultimate UHD Drives Flashing Guide Updated 2025
john769
Re: Ultimate UHD Drives Flashing Guide Updated 2021
Post by john769 »
Hey, so i'm new here after reading most of the thread the main point i got :
Desktop drive have more failure rate compared to 2.5 slim and to fix sleeping bug on desktop drive you need to flash to WH16NS60 Firmware...
ok so far so good but does 2.5 slim drive like BU40N or BP60NB10 have a sleeping bug ?
john769 wrote:
Mon Feb 22, 2021 8:47 am
No sleep bug on either of those
john769
Post by john769 »
thanks, i ordered BP60NB10 it will take couple of days to arrive...
so i guess it will come with encrypted ver "HL-DT-ST-BD-RE_BP60NB10-1.02-N000800-212005070935.bin"...
so i have to to check the box encrypted using modified ASUS Flasher...
ok, my question do i need to downgrade afer that to old ver to work with makemkv or 1.02 will work fine ?
john769 wrote:
Sun Feb 28, 2021 10:46 am
If fw is encrypted, flash using SDFtool Flasher with "enc?" checked. Then flash again to BP60NB10 1.01 from the MK firmware pack (without "enc?" cheked). This fw seems to work best on this drive.
KidJoe
Post by KidJoe »
I flashed my WH16NS40 (SVC NS50) drive to 1.02 a long time ago and everything has been working.
It reports
OS device name: G:
Product: BD-RE WH16NS40
Revision: 1.02
Serial number: xxxxxx
Firmware date: 2117-03-10 16:50
Highest AACS version: 76
Firmware version: 1.02
As I read this thread, I see the OP and a lot of a lot of talk recommending flashing the WH16NS40 drive with the WH16NS60 firmware which makes the drive perform as if it was a 16NS60 drive, which might be faster read performance? Am I reading that right?
How much faster is the read performance between a 16NS40 and a 16NS60? Is it worth flashing now or should I leave it alone because everything is working?
If I flash the WH16NS60 firmware on my WH16NS40 drive, will it impact the ability to write a disc if I need to?
If your drive is working fine, I'd leave it alone.
john769
Post by john769 »
so i got BP60NB10 today and as predicate come with 1.02 encrypted so flashed to "HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935" with "enc?" checked then to "HL-DT-ST-BD-RE_BP60NB10-1.01-NM01801-211905031534" without "enc?" cheked...
started to rip work great so far tried 2 disk so far no reading error :D
speed goes up and down but most of the time stays around 15.1 M/s (3.5X) ...
40min for disk 1 43gb...
18min for disk 2 20gb...
john769
Post by john769 »
so i did something stupid, i started to get hash error and the drive keep disconnected so i treid to flash back to 1.02 did'nt work the the same issue appears again so flashed to 1.01 and then 1.0 but nothing :oops:
so i flashed to DE_LG_BU40N_1.00 and nothing :?:
then i rememebed that my system ryzen r9 5950x with x570 has usb bug so i turned off c-states and put PCIE GEN 4 TO GEN 3 ...
the drive stop disconnecting but still get hash error.
so how can i limited the drive to max speed 2x ???
john769
Post by john769 »
also now i'm unable to flash back to BP60NB10 when i flash it keep showing up LG_BU40N_1.00... :o
john769 wrote:
Wed Mar 03, 2021 9:00 pm
Use the SDFtool Flasher's recovery option. It should work fine to get your drive back to BP60NB10 1.01 MK.
john769
Post by john769 »
not that important to flash back since the drive work with LG_BU40N 1.0...
so far i backup around 10 disks only the one disk gave me hash error and it was 25 gb single layer but after 5 time it mange to backup the disk, and the other disks 50gb work no hash error first try...
so far so good let hop the drive
john769
Post by john769 »
so the problem that i encountered with BP60NB10 mostly on disk under 25gb sometime hash error and other "DEBUG: Code 3221225664 at jot[uQ>o.oH&@FAI:29399197" ???
i tried multiple 25gb disks to backup but the same so i guess the drive is damaged ?
I ordered cheap second drive LG WH14NS40 let hope it work...
john769 wrote:
Sat Mar 06, 2021 1:25 pm
LG's in general are quite well know for not being very good at writing to disc.
I recommend not writing to disc at all and use HDD storage for your movies.
buffyp00h
Post by buffyp00h »
Hi forum.
So I just followed this wonderful guide to flash my LG BH16NS55 to the HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936 firmware.
Awesome stuff. I can now rip by 4K blurays. Thanks a lot for the guide and the magic behind it.
I did get a weird problem though after the firmware change. Every time I insert a music CD into my drive, it auto-ejects immediately. I am one of those 5 people who still buy CDs and rip them in EAC, so I really like my drive to be able to continue to read CDs.
Anyone else had this problem and know of a fix or a workaround?
Thanks a million for any response.
bradwiggo
Post by bradwiggo »
Hi, the guide mentions you need a particular "drive platform", can drives have different platforms even if they are the same model? Looking at a LG WH16NS60 on eBay. (Also, they say in description it can play 4k blu rays, does this mean it can rip them too?)
