Can I flash LG WH14NS40 1.05 directly to Re LG BH16NS40 1.03
Brand4KOn
#1 Post by Brand4KOn » Sun Feb 21, 2021 2:31 pm
This is what it says about my drive when I open MakeMKV (and yes I want to burn 4K blu rays):
Product: BD-RE WH14NS40
Revision: 1.05
Serial number: xxxxxxxxxxx
Highest AACS version: 66
Harware support: Yes
Firmware support: No
Firmware version: 1.05
Re: Can I flash LG WH14NS40 1.05 directly to Re LG BH16NS40 1.03
#2 Post by Woodstock » Sun Feb 21, 2021 5:11 pm
What does the flashing guide say?
And "burning 4K" is going to suffer if you flash the drives - reliably writing Bluray and BDXL disks tends to suffer. Somewhat ironically, the drives people find most reliable for WRITING BDXL are Pioneer drives, which aren't compatible with ripping 4K disks.
#3 Post by Coopervid » Sun Feb 21, 2021 5:32 pm
The LG drives only burn single layer BDs (25GB) OK. If you burn double layer discs (50GB) you will have read errors at the layer break. You will need a Pioneer drive and slow down burn speed to 4x, better 2x, for results without errors around the layer break.
Brand4KOn
#4 Post by Brand4KOn » Sun Feb 21, 2021 5:35 pm
I also want to Rip 4K movies/media for archive
Brand4KOn
#5 Post by Brand4KOn » Sun Feb 21, 2021 5:41 pm
Why does it say "BDXL™ Support" then if it doesn't even burn properly?
#6 Post by Woodstock » Sun Feb 21, 2021 7:17 pm
Just to make sure, when you say "burn 4k", you are referring to creating new 4K disks and writing them to a blank disk, correct?
A lot of people think "ripping" is "burning", when they are the opposite actions. "Ripping" is pulling data off the disk, "burning" is writing data to a blank disk.
If you wish to do both reliably, separate drives is the way to go..
Brand4KOn
#7 Post by Brand4KOn » Sun Feb 21, 2021 9:14 pm
I want to be able to do both, but at this point I may just settle with creating new 4K Blu rays (burning) which I don't believe requires flashing (if that feature even works at all).
#8 Post by Coopervid » Sun Feb 21, 2021 9:37 pm
No. You need to flash the LG compatible drives for ripping. This is a must.
If you want to burn the rips reliably you also need a Pioneer drive later on.
Brand4KOn
#9 Post by Brand4KOn » Sun Feb 21, 2021 11:09 pm
So is this drive not good enough to create my own 4K (media) discs? Example: 4K fan edits
