NiCE77
Post
by NiCE77 » Fri Feb 19, 2021 6:29 am
dysprosium wrote: Fri Feb 19, 2021 3:24 am
RESET_9999 wrote: Thu Feb 18, 2021 6:22 pm
NiCE77 wrote: Thu Feb 18, 2021 5:46 pm
I've tested the Ugoos AM6 Plus media player (Amlogic S922X-J), and it seems, the internal player correctly processing the
Full
Enhancement
Layer from DTDL mp4 file!
https://youtu.be/RYeLEYk_Bys
I'm tried with Kodi 19 custom build and working same with the P7 STDL mkv too!
thanks for confirming! very interesting...
does it support lossless audio as well? frame rate match?
Are you sure? It supports lossless audio passthrough in CoreELEC, but in Android I have only
seen people complain that lossless audio passthrough doesn't work due to a bug from Amlogic. The MINIX NEO U22X-J, which also runs on the S922X-J, has the
exact same problem, which they are also waiting on Amlogic to resolve.
Can you personally confirm that TrueHD/DTS-HD MA is being passed through on the AM6 Plus in Android (e.g. with a picture/video of the front display of your receiver showing TrueHD/DTS-HD MA)?
Only with Kodi:
https://4pda.ru/forum/index.php?showtop ... ry99107648
andyy
Post
by andyy » Sat Feb 20, 2021 1:54 pm
NiCE77 wrote: Thu Feb 18, 2021 7:28 pm
shawnc22 wrote: Thu Feb 18, 2021 7:17 pm
NiCE77 wrote: Thu Feb 18, 2021 6:43 pm
Yes, both
have you also tried Plex since it should already be supporting P7 STDL mkvs?
I will try tomorrow.
Did you try with Plex?
NiCE77
Post
by NiCE77 » Sat Feb 20, 2021 7:35 pm
andyy wrote: Sat Feb 20, 2021 1:54 pm
Yes, it seems Plex the best option.
These are working fine:
- Profile 5 STSL mp4
- Profile 7 STDL MEL/FEL mkv
- Profile 7 STDL MEL/FEL mp4
- Profile 8 STSL ts
yossSP
Post
by yossSP » Sun Feb 21, 2021 3:20 am
Ok thanks, well as far as I know, LLDV if it's well made doesn't have to be worst than TV-LED.
The quality I observe in FEL files playback is really good, but I don't have any reference to compare with.
DaMacFunkin
Post
by DaMacFunkin » Sun Feb 21, 2021 8:16 am
yossSP wrote: Sun Feb 21, 2021 3:20 am
Most people I have come across with LG OLED prefer TV led, myself included.
Did you test the scene in Total Recall?
NiCE77
Post
by NiCE77 » Sun Feb 21, 2021 8:47 am
knuffi123 wrote: Thu Feb 18, 2021 9:52 pm
Does it support UHD Menu like the Dune 4k Pro Player?
No.
yossSP
Post
by yossSP » Sun Feb 21, 2021 10:56 am
DaMacFunkin wrote: Sun Feb 21, 2021 8:16 am
Thanks for your answer, yes I know what you said, but is possible a LLDV without notice the difference.
I read about the test of the scene of Total Recall. I would like to pass it but I don't have this film in DV. Wich version is it? the original film of 1990 or the remake of 2012?.
You know if there is any cut of the concrete scene so I could test it?
mattmarsden
Post
by mattmarsden » Sun Feb 21, 2021 11:53 am
NiCE77 wrote: Sat Feb 20, 2021 7:35 pm
- Profile 8 STSL ts
What version of plex did you use?
NiCE77
Post
by NiCE77 » Sun Feb 21, 2021 12:58 pm
mattmarsden wrote: Sun Feb 21, 2021 11:53 am
- Profile 8 STSL ts
Server: 1.21.4.4054
Client: 8.13.1.23036
And Profile 7 STDL ts is working too (left out of the list).
mattmarsden
Post
by mattmarsden » Sun Feb 21, 2021 1:11 pm
NiCE77 wrote: Sun Feb 21, 2021 12:58 pm
- Profile 8 STSL ts
Server: 1.21.4.4054
Could you tell me what your Plex settings are as I can’t get it to play STDL mkv. Thanks
NiCE77
Post
by NiCE77 » Sun Feb 21, 2021 1:36 pm
mattmarsden wrote: Sun Feb 21, 2021 1:11 pm
Server: 1.21.4.4054
I didn't have to set anything on it.
NiCE77
Post
by NiCE77 » Sun Feb 21, 2021 1:39 pm
@RESET_9999
Please help this user
I tried to use tsmuxer to make bd folder and iso from dtdl mp4 but Dune is playing incorrectly:
https://www.avsforum.com/threads/dune-h ... t-60517880
mattmarsden
Post
by mattmarsden » Sun Feb 21, 2021 1:53 pm
NiCE77 wrote: Sun Feb 21, 2021 1:36 pm
Server: 1.21.4.4054
OK, I can’t get Plex to play mkv FEL. Kodi 19 will play them but its often choppy and some wont play at all. MEL plays fine
Post
by Manixx2020beyound » Sun Feb 21, 2021 2:15 pm
The original test file has to be re-created.
Baer2021
Post
by Baer2021 » Sun Feb 21, 2021 2:46 pm
Server: 1.21.4.4054
Can you please detail what your playback setup is again? I think you mentioned you're using Ugoos AM6 Plus player and are using Plex, is that correct? And you're having no issues with DV MKV playback along with the other formats you listed?
Also, is Dolby Atmos and other lossless formats still triggered using this player?
