chros
Post
by chros » Wed Feb 17, 2021 8:36 pm
quietvoid wrote: ↑Wed Feb 17, 2021 1:56 pm
chros wrote: ↑Wed Feb 17, 2021 7:46 am
Can we playback single layer DV (profile 5) mkv (!) with Firestick4k? If so, how? Thanks
Yes you can, with Kodi (
https://forum.kodi.tv/showthread.php?tid=360018) or Plex.
There is also a demo ExoPlayer app but it has to be launched from Kodi and requires a specific config for that.
Thank You, Kodi works great (although I had to install an NFS server on Win10 to get acces to files, smb didn't work from Kodi for whatever reason).
And thanks all the work You did as well with these DV projects!
afss_br
Post
by afss_br » Thu Feb 18, 2021 3:54 pm
Hi there, I could not get SMB working on Kodi 19 either. I am using the DV modified Kodi and it works like a charm on Nvidia Shield for both MEL and FEL MKV DV files.
What program have you used for NFS sharing on Windows 10 ? I could not get it to fully work - I was able to visualize the files on Kodi via NFS share, but they would not play...
chros
Post
by chros » Thu Feb 18, 2021 5:32 pm
afss_br wrote: ↑Thu Feb 18, 2021 3:54 pm
WinNFSd command line util, and I had to specify an alias and set the adress manually in Kodi.
NiCE77
Post
by NiCE77 » Thu Feb 18, 2021 5:46 pm
I've tested the Ugoos AM6 Plus media player (Amlogic S922X-J), and it seems, the internal player correctly processing the
Full
Enhancement
Layer from DTDL mp4 file!
https://youtu.be/RYeLEYk_Bys
I'm tried with Kodi 19 custom build and working same with the P7 STDL mkv too!
Post
by RESET_9999 » Thu Feb 18, 2021 6:22 pm
NiCE77 wrote: ↑Thu Feb 18, 2021 5:46 pm
Full
Enhancement
thanks for confirming! very interesting...
does it support lossless audio as well? frame rate match?
NiCE77
Post
by NiCE77 » Thu Feb 18, 2021 6:43 pm
RESET_9999 wrote: ↑Thu Feb 18, 2021 6:22 pm
Full
Enhancement
Yes, both
![Smile :)](./images/smilies/icon_smile.gif)
Post
by shawnc22 » Thu Feb 18, 2021 7:17 pm
NiCE77 wrote: ↑Thu Feb 18, 2021 6:43 pm
Full
Enhancement
Yes, both
have you also tried Plex since it should already be supporting P7 STDL mkvs?
NiCE77
Post
by NiCE77 » Thu Feb 18, 2021 7:28 pm
shawnc22 wrote: ↑Thu Feb 18, 2021 7:17 pm
Yes, both
I will try tomorrow.
knuffi123
Post
by knuffi123 » Thu Feb 18, 2021 9:52 pm
Does it support UHD Menu like the Dune 4k Pro Player?
dysprosium
Post
by dysprosium » Fri Feb 19, 2021 3:24 am
Full
Enhancement
Are you sure? It supports lossless audio passthrough in CoreELEC, but in Android I have only
seen people complain that lossless audio passthrough doesn't work due to a bug from Amlogic. The MINIX NEO U22X-J, which also runs on the S922X-J, has the
exact same problem, which they are also waiting on Amlogic to resolve.
Can you personally confirm that TrueHD/DTS-HD MA is being passed through on the AM6 Plus in Android (e.g. with a picture/video of the front display of your receiver showing TrueHD/DTS-HD MA)?
NiCE77
Post
by NiCE77 » Fri Feb 19, 2021 6:29 am
dysprosium wrote: ↑Fri Feb 19, 2021 3:24 am
Full
Enhancement
Only with Kodi:
https://4pda.ru/forum/index.php?showtop ... ry99107648
andyy
Post
by andyy » Sat Feb 20, 2021 1:54 pm
NiCE77 wrote: ↑Thu Feb 18, 2021 7:28 pm
Yes, both
Did you try with Plex?
NiCE77
Post
by NiCE77 » Sat Feb 20, 2021 7:35 pm
andyy wrote: ↑Sat Feb 20, 2021 1:54 pm
Yes, it seems Plex the best option.
These are working fine:
- Profile 5 STSL mp4
- Profile 7 STDL MEL/FEL mkv
- Profile 7 STDL MEL/FEL mp4
- Profile 8 STSL ts
yossSP
Post
by yossSP » Sun Feb 21, 2021 3:20 am
Ok thanks, well as far as I know, LLDV if it's well made doesn't have to be worst than TV-LED.
The quality I observe in FEL files playback is really good, but I don't have any reference to compare with.
DaMacFunkin
Post
by DaMacFunkin » Sun Feb 21, 2021 8:16 am
yossSP wrote: ↑Sun Feb 21, 2021 3:20 am
Most people I have come across with LG OLED prefer TV led, myself included.
Did you test the scene in Total Recall?
