WinNFSd command line util, and I had to specify an alias and set the adress manually in Kodi.afss_br wrote: ↑Thu Feb 18, 2021 3:54 pmHi there, I could not get SMB working on Kodi 19 either. I am using the DV modified Kodi and it works like a charm on Nvidia Shield for both MEL and FEL MKV DV files.
What program have you used for NFS sharing on Windows 10 ? I could not get it to fully work - I was able to visualize the files on Kodi via NFS share, but they would not play...
I've tested the Ugoos AM6 Plus media player (Amlogic S922X-J), and it seems, the internal player correctly processing the Full Enhancement Layer from DTDL mp4 file!
https://youtu.be/RYeLEYk_Bys
I'm tried with Kodi 19 custom build and working same with the P7 STDL mkv too!
thanks for confirming! very interesting...NiCE77 wrote: ↑Thu Feb 18, 2021 5:46 pmI've tested the Ugoos AM6 Plus media player (Amlogic S922X-J), and it seems, the internal player correctly processing the Full Enhancement Layer from DTDL mp4 file!
does it support lossless audio as well? frame rate match?
Yes, bothRESET_9999 wrote: ↑Thu Feb 18, 2021 6:22 pmthanks for confirming! very interesting...NiCE77 wrote: ↑Thu Feb 18, 2021 5:46 pmI've tested the Ugoos AM6 Plus media player (Amlogic S922X-J), and it seems, the internal player correctly processing the Full Enhancement Layer from DTDL mp4 file!
have you also tried Plex since it should already be supporting P7 STDL mkvs?NiCE77 wrote: ↑Thu Feb 18, 2021 6:43 pmYes, bothRESET_9999 wrote: ↑Thu Feb 18, 2021 6:22 pmthanks for confirming! very interesting...NiCE77 wrote: ↑Thu Feb 18, 2021 5:46 pmI've tested the Ugoos AM6 Plus media player (Amlogic S922X-J), and it seems, the internal player correctly processing the Full Enhancement Layer from DTDL mp4 file!
does it support lossless audio as well? frame rate match?![]()
I will try tomorrow.shawnc22 wrote: ↑Thu Feb 18, 2021 7:17 pmhave you also tried Plex since it should already be supporting P7 STDL mkvs?NiCE77 wrote: ↑Thu Feb 18, 2021 6:43 pmYes, bothRESET_9999 wrote: ↑Thu Feb 18, 2021 6:22 pm
Does it support UHD Menu like the Dune 4k Pro Player?
dysprosium
Are you sure? It supports lossless audio passthrough in CoreELEC, but in Android I have only seen people complain that lossless audio passthrough doesn't work due to a bug from Amlogic. The MINIX NEO U22X-J, which also runs on the S922X-J, has the exact same problem, which they are also waiting on Amlogic to resolve.RESET_9999 wrote: ↑Thu Feb 18, 2021 6:22 pmthanks for confirming! very interesting...NiCE77 wrote: ↑Thu Feb 18, 2021 5:46 pmI've tested the Ugoos AM6 Plus media player (Amlogic S922X-J), and it seems, the internal player correctly processing the Full Enhancement Layer from DTDL mp4 file!
Can you personally confirm that TrueHD/DTS-HD MA is being passed through on the AM6 Plus in Android (e.g. with a picture/video of the front display of your receiver showing TrueHD/DTS-HD MA)?
Only with Kodi:dysprosium wrote: ↑Fri Feb 19, 2021 3:24 amAre you sure? It supports lossless audio passthrough in CoreELEC, but in Android I have only seen people complain that lossless audio passthrough doesn't work due to a bug from Amlogic. The MINIX NEO U22X-J, which also runs on the S922X-J, has the exact same problem, which they are also waiting on Amlogic to resolve.RESET_9999 wrote: ↑Thu Feb 18, 2021 6:22 pmthanks for confirming! very interesting...NiCE77 wrote: ↑Thu Feb 18, 2021 5:46 pmI've tested the Ugoos AM6 Plus media player (Amlogic S922X-J), and it seems, the internal player correctly processing the Full Enhancement Layer from DTDL mp4 file!
https://4pda.ru/forum/index.php?showtop ... ry99107648
Yes, it seems Plex the best option.
These are working fine:
- Profile 5 STSL mp4
- Profile 7 STDL MEL/FEL mkv
- Profile 7 STDL MEL/FEL mp4
- Profile 8 STSL ts
Ok thanks, well as far as I know, LLDV if it's well made doesn't have to be worst than TV-LED.RESET_9999 wrote: ↑Wed Feb 17, 2021 8:27 pmHe has the HDfury Vertex which can tell if it's lldv or tv-led DV.
https://www.youtube.com/watch?v=e_a77zJTrO4
The quality I observe in FEL files playback is really good, but I don't have any reference to compare with.
DaMacFunkin
Most people I have come across with LG OLED prefer TV led, myself included.yossSP wrote: ↑Sun Feb 21, 2021 3:20 amOk thanks, well as far as I know, LLDV if it's well made doesn't have to be worst than TV-LED.RESET_9999 wrote: ↑Wed Feb 17, 2021 8:27 pmHe has the HDfury Vertex which can tell if it's lldv or tv-led DV.
Did you test the scene in Total Recall?
Thanks for your answer, yes I know what you said, but is possible a LLDV without notice the difference.DaMacFunkin wrote: ↑Sun Feb 21, 2021 8:16 amMost people I have come across with LG OLED prefer TV led, myself included.yossSP wrote: ↑Sun Feb 21, 2021 3:20 amOk thanks, well as far as I know, LLDV if it's well made doesn't have to be worst than TV-LED.RESET_9999 wrote: ↑Wed Feb 17, 2021 8:27 pmHe has the HDfury Vertex which can tell if it's lldv or tv-led DV.
I read about the test of the scene of Total Recall. I would like to pass it but I don't have this film in DV. Wich version is it? the original film of 1990 or the remake of 2012?.
You know if there is any cut of the concrete scene so I could test it?
