NiCE77
Post by NiCE77 »
shawnc22 wrote: Thu Feb 18, 2021 7:17 pm
NiCE77 wrote: Thu Feb 18, 2021 6:43 pm
RESET_9999 wrote: Thu Feb 18, 2021 6:22 pm
thanks for confirming! very interesting...
does it support lossless audio as well? frame rate match?
Yes, both :)
have you also tried Plex since it should already be supporting P7 STDL mkvs?
I will try tomorrow.
knuffi123
Post by knuffi123 »
Does it support UHD Menu like the Dune 4k Pro Player?
dysprosium
Post by dysprosium »
NiCE77 wrote: Thu Feb 18, 2021 5:46 pm I've tested the Ugoos AM6 Plus media player (Amlogic S922X-J), and it seems, the internal player correctly processing the Full Enhancement Layer from DTDL mp4 file!
https://youtu.be/RYeLEYk_Bys
I'm tried with Kodi 19 custom build and working same with the P7 STDL mkv too!
Are you sure? It supports lossless audio passthrough in CoreELEC, but in Android I have only seen people complain that lossless audio passthrough doesn't work due to a bug from Amlogic. The MINIX NEO U22X-J, which also runs on the S922X-J, has the exact same problem, which they are also waiting on Amlogic to resolve.
Can you personally confirm that TrueHD/DTS-HD MA is being passed through on the AM6 Plus in Android (e.g. with a picture/video of the front display of your receiver showing TrueHD/DTS-HD MA)?
NiCE77
Post by NiCE77 »
dysprosium wrote: Fri Feb 19, 2021 3:24 am
Only with Kodi:
https://4pda.ru/forum/index.php?showtop ... ry99107648
andyy
Post by andyy »
NiCE77 wrote: Thu Feb 18, 2021 7:28 pm
Yes, both :)
Did you try with Plex?
NiCE77
Post by NiCE77 »
andyy wrote: Sat Feb 20, 2021 1:54 pm
Yes, it seems Plex the best option.
These are working fine:
- Profile 5 STSL mp4
- Profile 7 STDL MEL/FEL mkv
- Profile 7 STDL MEL/FEL mp4
- Profile 8 STSL ts
yossSP
Post by yossSP »
RESET_9999 wrote: Wed Feb 17, 2021 8:27 pm He has the HDfury Vertex which can tell if it's lldv or tv-led DV.
https://www.youtube.com/watch?v=e_a77zJTrO4
Ok thanks, well as far as I know, LLDV if it's well made doesn't have to be worst than TV-LED.
The quality I observe in FEL files playback is really good, but I don't have any reference to compare with.
DaMacFunkin
Post by DaMacFunkin »
yossSP wrote: Sun Feb 21, 2021 3:20 am
Most people I have come across with LG OLED prefer TV led, myself included.
Did you test the scene in Total Recall?
NiCE77
Post by NiCE77 »
knuffi123 wrote: Thu Feb 18, 2021 9:52 pm Does it support UHD Menu like the Dune 4k Pro Player?
No.
yossSP
Post by yossSP »
DaMacFunkin wrote: Sun Feb 21, 2021 8:16 am
Thanks for your answer, yes I know what you said, but is possible a LLDV without notice the difference.
I read about the test of the scene of Total Recall. I would like to pass it but I don't have this film in DV. Wich version is it? the original film of 1990 or the remake of 2012?.
You know if there is any cut of the concrete scene so I could test it?
mattmarsden
Post by mattmarsden »
NiCE77 wrote: Sat Feb 20, 2021 7:35 pm
- Profile 8 STSL ts
What version of plex did you use?
NiCE77
Post by NiCE77 »
mattmarsden wrote: Sun Feb 21, 2021 11:53 am
- Profile 8 STSL ts
Server: 1.21.4.4054
Client: 8.13.1.23036
And Profile 7 STDL ts is working too (left out of the list).
mattmarsden
NiCE77 wrote: Sun Feb 21, 2021 12:58 pm
- Profile 8 STSL ts
Server: 1.21.4.4054
Could you tell me what your Plex settings are as I can’t get it to play STDL mkv. Thanks
NiCE77
Post by NiCE77 »
mattmarsden wrote: Sun Feb 21, 2021 1:11 pm
Server: 1.21.4.4054
I didn't have to set anything on it.
NiCE77
Post by NiCE77 »
@RESET_9999
Please help this user :)
I tried to use tsmuxer to make bd folder and iso from dtdl mp4 but Dune is playing incorrectly: https://www.avsforum.com/threads/dune-h ... t-60517880
