Roberespa
#4411 Post by Roberespa » Mon Feb 15, 2021 12:17 pm
-Hello:
Could you provide me with the links to the latest version of
-python
-mp4muxer
and the one that brings everything incorporated including FFmpeg (The version that a user made that brings everything together).
Thanks a lot.
Please, I can't find the last x32 and 64 Bits (python)!
Give me a hand
-Greetings to Crodiales. :|
deadchip12
#4412 Post by deadchip12 » Mon Feb 15, 2021 1:29 pm
Vlc 4.0 is announced, but no dolby vision support. Sad.
lexyz
#4413 Post by lexyz » Mon Feb 15, 2021 3:41 pm
staknhalo wrote:
Mon Feb 15, 2021 12:03 am
If I don't care about per-pixel-perfection, outside of very obvious negative artifacts - would converting to profile 8 be best for broadest device playback compatibility vs keeping profile 7?
Yes
daicon
#4414 Post by daicon » Mon Feb 15, 2021 10:45 pm
XTrojan wrote:
Fri Jan 29, 2021 11:46 pm
Anyone know if the new Google ChromeCast (4th generation) can playback DV BluRays formats with full support FEL etc?
Here say that work DV FEL:
https://www.avpasion.com/foro/t/nuevo-c ... -mel.3588/
Any try?
is true?
#4415 Post by shawnc22 » Tue Feb 16, 2021 1:43 am
Any try?
is true?
I'm skeptical. Even if it's capable of playing FEL, I suspect that it's just ignoring the EL like what the Shield is doing. I highly doubt that the Chromecast has the dual decoders needed to properly playback FEL.
daicon
#4416 Post by daicon » Tue Feb 16, 2021 7:55 am
Any try?
is true?
I understand.
I have written in the forum, asking you to use the samples that were uploaded here to check if a device is removing the FEL "layer".
Let's see if in the meantime, someone has more information.
yossSP
#4417 Post by yossSP » Tue Feb 16, 2021 8:14 am
Any try?
is true?
Hi all, I have made the test with the new Chromecast with Google TV (CCWGTV)
Test platform:
  • TV OLED Panasonic TX-65HZ1000
  • Emby/Plex beta MediaServer on Windows 10 Pro 64 bits
  • Chromecast with Google TV (2020)
The results:
  • test DT DL FEL: playback as HDR10 (CCWGTV can't play dual track DV)
  • test SL p8 RPU: playback as HDR10 (without noise)
  • test ST DL FEL: playback as DV with noise during 5 seconds
test ST DL FEL
https://ibb.co/p4mQSgr
test SL p8 RPU
https://ibb.co/rbCXb8V
Latest Emby beta can't play the file as DV it plays as HDR10, but I can do it with latest Plex beta, but only during 5 seconds, rendering the noise of the FEL layer as the picture shows .
After this 5 seconds Plex stops the playback and shows an error saying something like there isn't enought power to decode the file. I receive this error when Plex can't play a file without transcoding because I disable transcoding in Plex, but it never has ben shown in the middle of a playback, it always show before rendering.
Well, after the last firmware update on february this little device never ceases to amaze me.
Also I can play with latest Plex beta FEL files of 90Mb/s without issues.
So, after these results, can we say that this device fully supports FEL media?
staknhalo
#4418 Post by staknhalo » Tue Feb 16, 2021 2:00 pm
Is there a trick to enabling HDR10 base layer on a DV P8.1 file? When I make one, the DV metadata/part is enabled/plays fine, but when I disable DV, the HDR10 base layer is there (obvious, I muxed it in) but it's not playing in HDR10 - there are no highlights at all. Everything is muted like 10-bit color data is there, but highlight/brightness part metadata removed. Mediainfo shows DV P8-1 with HDR10 BL/HDR10 compatibility though.
'mp4muxer --dv-profile 8 --dv-bl-compatible-id 1 --input-file Video.hevc --input-file Audio.aac --media-lang eng --output-file FILENAME.mp4'
'--dv-bl-compatible-id 1' - is for the HDR10 BL, '--dv-bl-compatible-id 2' would be for an SDR layer, am I missing some more mux commands I needed?
Ride_UL
#4419 Post by Ride_UL » Tue Feb 16, 2021 3:15 pm
So.. i started using .m2ts container instead of .ts (via TSMuxer) and now PGS Subtitles are working just fine with MrMC :D
#4420 Post by shawnc22 » Tue Feb 16, 2021 6:05 pm
Any try?
is true?
Test platform:
The results:
test ST DL FEL
test SL p8 RPU
Wow, that is definitely a pleasant surprise. Are you saying that with the latest firmware update, you can still only play the first 5 seconds with Plex beta? Is it maybe trying to transcode because you selected one of the lossless audio tracks? Not supporting lossless audio is still a bit of a deal breaker for me, but it definitely shows promise for future devices.
#4421 Post by RESET_9999 » Tue Feb 16, 2021 8:17 pm
indeed, very surprising to see a streaming device supporting FEL.
Now I wonder which Chromecast Manix tested a while ago because the colors were slightly more saturated (no red spot and better than the shield though). Unfortunately, Manix vanished since he told me that he received his Dune UHD a week ago. :(
daicon
#4422 Post by daicon » Tue Feb 16, 2021 9:10 pm
we do not know if the tests were done with the last generation of Chromecast?
#4423 Post by RESET_9999 » Tue Feb 16, 2021 9:22 pm
probably not the latest generation indeed... I wish @Manix(the guy with the Atomos shogun device) could confirm but he won't respond to me anymore, he's gone (probably personal issues) ...
knuffi123
#4424 Post by knuffi123 » Tue Feb 16, 2021 11:09 pm
Hi, I think about getting a Sony x700 and just wanted to make sure if I understand correctly, that the x700 is able to play DV P8 dual layer m2ts/ts fine? Is this independent from MEL and FEL? So no issues with FEL?
Thank you!
#4425 Post by RESET_9999 » Wed Feb 17, 2021 1:08 am
Thank you!
the x700 can play all the DV profiles. So, yes it supports MEL / FEL-DV+ lossless audio TS/M2TS rip. I watched tons of DV movies and I never had a playback issue.
Just remux your UHD-BD with tsMuxer and you're good to go.
