I have a LG WH16NS40 that has been refreshed to WH16NS60 revision 1.03.In MakeMKV it shows:
OS device name: /dev/rdisk5
Current profile: DVD-ROM
Product: BD-RE WH16NS60
Revision: 1.03
Serial number: KLAKB6G2133
Firmware date: 2120-05-08 10:10
Highest AACS version: 68
Firmware version: 1.03
However, today I had my first glitch. This is not to do with MakeMKV which reads the disk just fine, but rather MacOS DVD player.
This is with the DVD of The Rocky Horror Picture show. Trying to play with DVDPlayer MacOS returns that "This disk is not formatted to play in this region". I have never had this before. I also have Blu-Ray Player Pro and that does read the disk is it is just a DVDPlayer issue.
Does anyone know how the DVD all regions in the WH16NS60 Rev 1.03 firmware represents the player's DVD region? Is it just set to region 0? Any any ideas on why DVDPlayer does not work with this?
BritGuy
Re: This disk is not formatted to play in this region
Only applications that know how to deal with LibreDrive will see the "all regions" part.
Mac DVD player isn't one of them - it talks to the "normal" interface.
BritGuy
Okay, so the drive was originally a region 1 drive. Would the flashing then have changed that, so say region 2?
Is it possible to change the "normal" interface back to region 1?
Why not just use MakeMKV to rip the thing and play the resulting .mkv file?
Or use makemkv integration + vlc
BritGuy
I may just be that one disk as others are okay. I am actually ripping it, but sometimes need to play the disk in a actual player to review menus etc to determine what to rip.dcoke22 wrote: Tue Feb 16, 2021 11:39 pm Why not just use MakeMKV to rip the thing and play the resulting .mkv file?
