Post by RESET_9999 » Sun Feb 07, 2021 5:55 pm
deadchip12 wrote:
Sun Feb 07, 2021 4:51 pm
even external subtitles won't work?
I don't know... I never tried. I use TS container for everything that is DV.
glc650
Post by glc650 » Sun Feb 07, 2021 11:56 pm
Why TS over m2ts?
Post by RESET_9999 » Mon Feb 08, 2021 12:28 am
Why TS over m2ts?
no particular reason. It's just the default tsMuxer output.
daddy
Post by daddy » Thu Feb 11, 2021 6:32 am
External subtitles works in mp4.
You just have to name the srt file exactly like the mp4 file.
SeaZe
Post by SeaZe » Fri Feb 12, 2021 2:04 am
Hi I have read a lot about how to get Dolby Vision with FEL to play on my LG CX. It seems like the internal player of LG CX can only play Dolby Vision with MEL and not FEL is this true? Also what filetypes can it play, can the LG CX play mkv with Dolby Vision MEL? Will the LG CX’s internal player never be able to play Dolby vision with FEL?
If the internal player is not the way to go would I have to get the x700 to play Dolby Vision with FEL, or could some of these chinese oppo clones do it? Which one should I get, would the M9702 v3 be able to play Dolby Vision FEL with lossless audio? I saw one that costs 50 dollars on ebay is this legit? Where can I see what devices play Dolby Vision with FEL and the filetypes supported?
I’m new to the scene and just got my LG CX a few weeks ago would really appericiate if somebody could answer my questions. I feel like it is so hard to get information on this stuff compared to other tech stuff. There is just this and avforums that talk about it
Post by shawnc22 » Fri Feb 12, 2021 7:56 pm
galarond wrote:
Fri Feb 12, 2021 6:48 pm
Im been reading for almost months now about this and the best choice is the lg ubk90 bluray player and use your external drive there, only till 2tb, it plays everything fine,but no isos or bluray rip carpets,so mkv, mp4, single dual layer all fine.
I don't know where you're getting your info from, but there have been no reports of the ubk90 being able to play dual layer files from any format outside of mp4, meaning it cannot do DL DV + lossless audio unless you're playing the physical disk. If you're reporting this info yourself from personal experience, then that's good news to the rest of us. The only devices that is confirmed capable of playing DL FEL DV + lossless audio is the x700/x800m2 (dual track m2ts/ts format) and the oppo 203/205 and its clones (bdmv/iso). And no, you will not find the oppo clones on ebay, especially not for under $300.
Post by shawnc22 » Sun Feb 14, 2021 4:57 am
galarond wrote:
Sun Feb 14, 2021 4:17 am
As i read the x700 cant reproduce the new mkv dolby vision movies, the dual layer ones, or the dual layers mixed in 1 video file inside the mkv, im i wrong?
Like I said, the x700 can only play them in m2ts/ts containers. There are no devices out there at the moment that can play FEL DV in mkvs with full accuracy.
tr000
Post by tr000 » Sun Feb 14, 2021 10:19 am
In general, yes, though some software has limited or no support for external .SRT files on .MP4 files (e.g., Windows Media Server).
blenky
Post by blenky » Sun Feb 14, 2021 11:09 pm
I have a Sony ubp-x700 player. Can someone explain how I can use that to play DV MT2S files? Do I have to copy them to USB or can I access files on my NAS? Cheers.
staknhalo
Post by staknhalo » Mon Feb 15, 2021 12:03 am
If I don't care about per-pixel-perfection, outside of very obvious negative artifacts - would converting to profile 8 be best for broadest device playback compatibility vs keeping profile 7?
Roberespa
Post by Roberespa » Mon Feb 15, 2021 12:17 pm
-Hello:
Could you provide me with the links to the latest version of
-python
-mp4muxer
and the one that brings everything incorporated including FFmpeg (The version that a user made that brings everything together).
Thanks a lot.
Please, I can't find the last x32 and 64 Bits (python)!
Give me a hand
-Greetings to Crodiales. :|
deadchip12
Post by deadchip12 » Mon Feb 15, 2021 1:29 pm
Vlc 4.0 is announced, but no dolby vision support. Sad.
lexyz
Post by lexyz » Mon Feb 15, 2021 3:41 pm
Yes
daicon
Post by daicon » Mon Feb 15, 2021 10:45 pm
XTrojan wrote:
Fri Jan 29, 2021 11:46 pm
Anyone know if the new Google ChromeCast (4th generation) can playback DV BluRays formats with full support FEL etc?
Here say that work DV FEL:
https://www.avpasion.com/foro/t/nuevo-c ... -mel.3588/
Any try?
is true?
Post by shawnc22 » Tue Feb 16, 2021 1:43 am
Any try?
is true?
I'm skeptical. Even if it's capable of playing FEL, I suspect that it's just ignoring the EL like what the Shield is doing. I highly doubt that the Chromecast has the dual decoders needed to properly playback FEL.
