BH16NS40 1.01 and CMCMAG-BA5-000 BR Disc
aragon
Post by aragon »
Hi:
I have an BH16NS40 1.0 drive and suddenly its starting failing in burning BR drives. I am using Verbatim BR disk CMCMAG-BA5-000 disk and it burned correctly plenty of them. But, now, when I burn at 4x speed sometimes it finish the disk and did not burn nothing, remains empty, others times burn but the disk is no readable at the end. If I try a 6x speed it says that can not make the Power Calibration.
Is this a disk problem or is this a BlueRay device problem? Should I inspect some logs? Should I think I buying a new one? Any test that I came make?
With my best regards and thanks for your help and guidance
