MakeMKV 1.15.4 rips fine on Win10, not on Debian 10
psilospiral
Post by psilospiral » Sun Feb 14, 2021 2:26 am
Greetings Forum:
I have just ripped a DVD successfully using MakeMKV 1.15.4 in Win10. I downloaded and compiled the Debian version following instructions found in the forum here: https://www.makemkv.com/forum/viewtopic ... 7e330a57ce
I am now attempting to rip the exact same DVD in Debian, but the process fails. 5 of 6 are successful, but the main movie track fails. I have turned on debug logging and the output is as follows:
Title #1 was added (28 cell(s), 1:26:27)
Title #2 was added (2 cell(s), 0:06:55)
Title #3 was added (1 cell(s), 0:07:20)
Title #4 has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 was added (1 cell(s), 0:02:15)
Title #6 has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 was added (3 cell(s), 0:04:31)
Title #8 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 was added (1 cell(s), 0:02:25)
DEBUG: Code 233 at X2kpcDqlFiLTtJjLZGm8T2XM:0
Saving 6 titles into directory /home/martin/Videos/FANTASTIC_MR_FOX
Unable to execute external program 'ccextractor' as its path is not set in preferences
DEBUG: Code 2 at zs\?-gf:*_r{CU8xqTvy:29394436
Failed to execute external program 'ccextractor' from location '/usr/bin/mmccextr'
DEBUG: Code 0 at {Iz{Lg4X/)T@\l?fOr2MA:213130628
DEBUG: Code 0 at v,U=z=pYj 4]>`rW:121264579
DEBUG: Code 0 at ";Dc&k*Q1J&C ]\:n(S~:121261773
DEBUG: Code 0 at 'H`0/SvLNHy!C,QyfoC94:213137068
Failed to save title 0 to file /home/martin/Videos/FANTASTIC_MR_FOX/title_t00.mkv
5 titles saved, 1 failed
I used stock MakeMKV settings in both OS variants. Does anybody have any idea what may be the problem?
Re: MakeMKV 1.15.4 rips fine on Win10, not on Debian 10
Post by Woodstock » Sun Feb 14, 2021 2:49 am
At least temporarily, deselect the Closed Caption track for that title, until you have your path to ccextractor set properly.
wmcclain wrote:
Mon Jan 18, 2021 2:05 pm
In Preferences, under Advanced, try this for ccextractor executable location:
/usr/bin/true
psilospiral
Post by psilospiral » Sun Feb 14, 2021 5:14 pm
Woodstock:
I would have never guessed the closed caption option would have been stopping the ripping process, so I just ignored that in my trouble shooting. I took your advice and decided to install ccextractor for completeness with:
sudo apt install ccextractor
which ccextractor
/usr/bin/ccextractor
Then I entered that path in makemkv with:
View>Preferences>General>Expert mode: CHECK
	#	Advanced tab is created
	>Advanced>ccextractor executable location: /usr/bin/ccextractor
		Apply, Ok
After this, I was able to rip the same DVD on Debian without issue!
I want to add that I also had to install libdvdcss before I could even play the DVD on a fresh copy of Debian 10 with:
#	install libdvdcss
sudo apt install libdvd-pkg
#	select ok ok
#	run below to set automatic upgrades of libdvdcss2
sudo dpkg-reconfigure libdvd-pkg
Thank you for your help!
