Source Code 'fake playlist'
bmillham
Post by bmillham »
This is my bad day for ripping blurays....
Second disc today with a fake playlist, Source Code (2011). Anyone know the correct title?
Lovely Rita
Re: Source Code 'fake playlist'
Post by Lovely Rita »
viewtopic.php?f=8&t=3876&hilit=Source+c ... =30#p15247
10 minutes of using SEARCH uncovered both this one and WONDER :wink:
Registered User :wink:
Buy MakeMKV
bmillham
Post by bmillham »
Thanks for spending so much time searching!!! I was going crazy; the search engine isn't really that good, is it.
Things like + don't seem to work properly, searching +Wonder +2017 returned all kinds of results that didn't have 2017 in it. Ran into the same thing with Source Code....
Lovely Rita
No problem!
Yes, certain searches are crapshoots.
Buy MakeMKV
ikomrad
Post by ikomrad »
Lovely Rita wrote: Sun Aug 26, 2018 4:36 am viewtopic.php?f=8&t=3876&hilit=Source+c ... =30#p15247
I don't see an answer in the thread your linked, but there is some good advice.
What I did was put the blu-ray in my Xbox One and play the main title. The player reported the movie length as 1:33:13 .
Then I scanned the titles that MakeMkv found. None of them matched exactly, but I found 2 that were 1:33:12
Title information
Name: Source Code (English)
Source file name: 00743.mpls
Duration: 1:33:12
Chapters count: 18
Segment count: 7
Segment map: 147,3,141,137,1,142,4
File name: Source_Code_t32.mkv
Title information
Source file name: 00876.mpls
Duration: 1:33:12
Chapters count: 18
Segment count: 7
File name: Source_Code_t41.mkv
They are identical except for the file name. I'm trying 00743.mpls and will report back my findings.
Lovely Rita
ikomrad wrote: Thu Oct 18, 2018 3:02 am
876.mpls was reported as correct in the linked thread. :wink:
Appears you're on the right track....
Buy MakeMKV
preserve
Post by preserve »
Does anyone know the correct title, segment map, runtime and # of chapters for the Canadian retail version of this?
All the playlists in this version start with segment map 4.
Annoying when there's different distributors in different countries, for potential quality reasons as well as playlists. Bought from Amazon.ca, Entertainment One release, 200119BRD.
preserve
Post by preserve »
A year later, and I finally got around to this lol... I'm often on a hunt to find the best release of a film, but in my early buying days I was more often just picking up the CA releases. So here are my latest findings on eOne's CA release of Source Code, and please forgive the length of this!
I might still get the US release for a final comparison, but for now I'm comparing the UK release to the CA release, believing the CA to be close if not identical to the US (unlike other films, no logos from Canadian distributor eOne were added to the movie itself, and the bitrates match the playlist report from caps-a-holic - the only difference seems to be that CA has French, US has Spanish). Don't get the original UK release. It has a weird 1 second of off-black at the start, and then the opening Optimum logo sits still on the screen for way too long... because it has to match the length of the US Summit logo, since the film's soundtrack plays underneath the logos. The encode of the UK release is not great. Fine gradations in the CA release turn into banding in the UK release, most noticeably in all the scenes inside the capsule. Your mileage may vary depending on the setup of your display.
The UK release has an average bitrate of 22.673, while the CA release has an average bitrate of 27.885.
As for the CA release, it seems to be a pre-Java obfuscation attempt, so MakeMKV doesn't detect it.
There are 3 candidate playlists for CA, given the proper number of chapters and the movie length. 756 is identical to 834 but has too many subtitles. 768 and 834 have 1 segment different - 147 and 3 - but upon visual and MediaInfo inspection of the different m2ts files, I then confirmed that they were identical using WinDiff file comparison. So believing both should be fine, I arbitrarily chose the first one 768, confirming that it has subtitles for both the feature and the audio commentary. As expected from the obfuscation branching, it had A/V Sync Errors using MakeMKV 1.15.4. I'll watch it shortly, but I'm not expecting any issues based on checking through the segments.
Disc Information
Label: SOURCE_CODE
Timestamp: 2011-06-06 18:52:42
Data capacity: 28.53 Gb
Disc type: BD-ROM
Number of layers: 2
Protection: AACS v25
Title information
Source file name: 00768.mpls
Duration: 1:33:12
Chapters count: 18
Segment count: 7
Segment map: 4,141,143,147,137,1,144
File name: Source Code_t36_s00768.mkv
Title information
Source file name: 00834.mpls
Duration: 1:33:12
Chapters count: 18
Segment count: 7
Segment map: 4,141,143,3,137,1,144
File name: Source Code_t39_s00834.mkv
Saving 1 titles into directory N:/Movies Blu-ray/Source Code CA
AV synchronization issues were found in file 'N:/Movies Blu-ray/Source Code CA/Source Code_t36_s00768.mkv' (title #37)
AV sync issue in stream 1,2 at 0:10:13.946 with duration of 5.333ms : encountered overlapping frame, audio skew is +5.333ms
AV sync issue in stream 1,2 at 0:12:18.612 with duration of 5.791ms : encountered overlapping frame, audio skew is +11.125ms
AV sync issue in stream 1 at 0:12:18.624 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.458ms
AV sync issue in stream 2 at 0:25:52.926 with duration of 22.5ms : encountered overlapping frame, audio skew is +33.625ms
AV sync issue in stream 2 at 0:25:52.960 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +1.625ms
AV sync issue in stream 1 at 0:25:52.926 with duration of 1.166ms : encountered overlapping frame, audio skew is +1.625ms
AV sync issue in stream 1 at 0:26:16.241 with duration of 2.375ms : encountered overlapping frame, audio skew is +4ms
AV sync issue in stream 2 at 0:26:16.241 with duration of 13.041ms : encountered overlapping frame, audio skew is +14.666ms
AV sync issue in stream 1 at 0:27:07.751 with duration of 10.208ms : encountered overlapping frame, audio skew is +14.208ms
AV sync issue in stream 1 at 0:27:07.765 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +3.541ms
AV sync issue in stream 2 at 0:27:07.751 with duration of 10.208ms : encountered overlapping frame, audio skew is +24.875ms
AV sync issue in stream 2 at 0:28:07.477 with duration of 17.666ms : encountered overlapping frame, audio skew is +42.541ms
AV sync issue in stream 2 at 0:28:07.520 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +10.541ms
AV sync issue in stream 1 at 0:28:07.477 with duration of 7ms : encountered overlapping frame, audio skew is +10.541ms
AV synchronization issues were found in file 'Source Code_t36_s00768.mkv' (title #37)
Forced subtitles track #4 turned out to be empty and was removed from output file
Forced subtitles track #6 turned out to be empty and was removed from output file
1 titles saved
Using: ASUS BW-16D1HT 3.00
jdunn0214@gmail.com
Post by jdunn0214@gmail.com »
Duration: 1:33:12
Chapters count: 18
Segment count: 7
File name: Source Code_t42.mkv
I have watched this version and believe its the correct one
