how to decrypt UHD from backup?
jpopte
#1 Post by jpopte » Wed Feb 10, 2021 2:49 am
In nutshell, is it possible to decrypt the encrypted UHD disk stored on the drive?
Sometime ago, I created the encrypted backup of UHD disk on the local drive using File/Backup option. It stored it in BDMV structure on the drive. Now, I load this UHD in makemkv from the local drive (e.g. by reading index.bdmv file) and want to decrypt this UHD and store it again on the BDMV structure on the drive. It loads and reads the encrypted BDMV file structure from the drive. At this point, the only option I am offered is to create MKV file from it. The "backup" menu item from File menu is greyed out. Could someone please help? Thanks.
jpopte
Re: how to decrypt UHD from backup?
#2 Post by jpopte » Fri Feb 12, 2021 3:55 am
Could anyone please help? Mike? Thanks!
#3 Post by Woodstock » Fri Feb 12, 2021 2:16 pm
If you are wanting to make MKV files out of it, you just open the encrypted backup's index.bdmv file; MakeMKV would have saved the information necessary to decrypt it when it was backed up.
If you want to turn it into an unencrypted backup, I cannot give exact advice, because I haven't done that before. But make sure you save the result to a DIFFERENT directory.
#4 Post by shawnc22 » Fri Feb 12, 2021 3:07 pm
you're gonna have to make an iso out of your encrypted backup and then mount it to a virtual drive. you can then have makemkv treat it like any other disc and do your decrypted backup.
jpopte
#5 Post by jpopte » Sat Feb 13, 2021 1:42 am
Yeah, I tried that (using PowerISO on Win10) and the ISO file mounts just fine. However, makemv (latest rev) does not recognize this mount at all. What could I be doing wrong with mounting the ISO file? Any suggestions on mounting the ISO? Thanks.
jpopte
#6 Post by jpopte » Sat Feb 13, 2021 1:43 am
....But make sure you save the result to a DIFFERENT directory.
Sure. Thanks.
#7 Post by shawnc22 » Sat Feb 13, 2021 3:57 am
I've used Virtual Clonedrive to do this exact workflow in the past and have had no issues.
jpopte
#8 Post by jpopte » Tue Feb 16, 2021 9:40 am
@ shawnc22, Thank You - you're right. Ultimately, the same worked for me - Virtual Clonedrive to create virtual drive and later mount using PowerISO or other tools. makeMKV recognized it.
makeMV DOES NOT recognize the virtual drive created by PowerISO. Very frustrating.
Is this a bug? Could makeMKV team look at this problem and possibly fix it please? Thanks.
