Does anyone know the playlist (mpls numbers) for the Netflix Series Narcos?
If not can anyone suggest a good way to verify the correct ones. They are not on a Lionsgate disc (Arrow) and therefore don't seem to trigger the Java Runtime checks.
Any help much appreciated.
Playlist for Narcos Blu Ray? Seasons 1 & 2
MercmayMKV10
Andrew
Re: Playlist for Narcos Blu Ray? Seasons 1 & 2
Same question as MercmayMKV10 - as I too am wondering which playlist (mpls) to use.
I have the Netflix Season One BluRay (3 Disc set) Season One by ArrowFilms (bar code 5 027035 015088) -- MakeMKV v1.16.3 [win(x64-release)] loads the first BluRay and shows about 415 (!) titles available for backing up.
Files are 12.8GB, 30.4GB, 9.1GB, 3.6GB -- the remainder are repeat of the 9.1GB and 12.8GB files, all with varying segment maps.
Thank you.
Thank you.
- Narcos Season One Disc One - MakeMkv.jpg (69.35 KiB) Viewed 4885 times
