Z Nation Season 2 errors
sfenwick
#1 Post by sfenwick » Thu Apr 14, 2016 1:32 am
This is for the UK Blu-rays. All of the episodes start about 1m30s too early (showing a test pattern), and end the same too soon (cut off).
Re: Z Nation Season 2 errors
#2 Post by Woodstock » Thu Apr 14, 2016 1:35 am
Not a lot of information to work from... Do you have the scan portion of the debug log that you can post?
sfenwick
#3 Post by sfenwick » Sat May 07, 2016 11:43 pm
Debug log started at Sat May 7 23:34:36 2016 , written by MakeMKV v1.9.10 darwin(x86-release)
001005:0000 MakeMKV v1.9.10 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/scf/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL HL-DT-ST DVD-RW GH61N PA03d" opened in OS access mode.
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE WH14NS40 1.00d" opened in OS access mode.
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE WH12LS38 1.00d" opened in OS access mode.
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE WH14NS40 1.01d" opened in OS access mode.
DEBUG: Code 2147483648 at \@%sryo|/N:Wmp?4:121265315
DAFD=PAAAADAAAAEABDQkEFwECAQ==
DCE=J/uukvH7KRxhm7jv2MQgRYH8POjsaZxZD4+bFBCax29NCRTfRbmNf4LDYx+LKUnfwOahjd0GxW6BGVfLUCec6EoiTKFgtprihtHCfugKFGix2lVv9b9r46jZWpv5KYkLyp9w4QMKGPGe4p3/oPPoiX71xqCi5CCqdQ==
DCE=fNCo9JEVAAgnQhsv0rPPVlXFDLQs7QD2ZqPa3jTSmR6HOnj72zcrbXitwOWLkDN3c3hZJ3l9mZKYKMe5dnUte1fEZxNGJpHrTziMYFteUaTA7FkweQ182VLDHcpWTTV7cQepdooGK+YWlPA/n9JPtrhwIHtyKqPI2g==
DISCID=D99B0FA449A376C67DE5F3A0F19549177E2C0D9C
003307:0000 File 00003.mpls was added as title #0
003307:0000 File 00002.mpls was added as title #1
003309:0000 Title 00005.mpls(12) is equal to title 00002.mpls and was skipped
003309:0000 Title 00005.mpls(18) is equal to title 00003.mpls and was skipped
003309:0000 Title 00003.m2ts is equal to title 00003.mpls and was skipped
003307:0000 File 00006.m2ts was added as title #2
003309:0000 Title 00002.m2ts is equal to title 00002.mpls and was skipped
003307:0000 File 00001.m2ts was added as title #3
003307:0000 File 00000.m2ts was added as title #4
003307:0000 File 00009.m2ts was added as title #5
003307:0000 File 00008.m2ts was added as title #6
005014:0000 Saving 1 titles into directory /Volumes/D2/Rips/Znation
005001:0308 File /Volumes/D2/Rips/Znation/Z_Nation_Season_2_Disc_1_t03.mkv already exist. Do you want to overwrite it?
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Application exited at Sat May 7 23:42:01 2016
-SilentAssassin-
#4 Post by -SilentAssassin- » Wed Feb 10, 2021 2:53 pm
I have a similar issue with the season 2 discs from the complete series set released in the UK. The episodes similarly start about 1:30 too early, but, rather than being cut off at the end, it goes on for several minutes past the end of the episode and includes some textless material from the episode for some reason. I also noticed that the produced MKVs don't include chapters, but, when I play the episodes from the disc, they definitely do have chapters. I'm not too worried about the chapters, and trimming off the extra bits is easy enough with mkvmerge, but I noticed when identifying the timestamps for the start and end of the actual episode that the episode runs longer in the MKV than from the disc. I haven't done this for every episode yet, but the two I have were both about 40 seconds longer. I haven't watched the whole episodes to confirm, but it seems like the MKV is slowed down slightly, as the difference in timestamps seems to get larger towards the end of the episode.
I also had a similar issue with the UK Blu-ray release of season 1 of The Good Place (also from Dazzler Media). I can't remember if there was anything extra at the end of the episodes, but there definitely was at the beginning, on at least some of the episodes. I never got around to trimming off the extra parts, so I don't know if those files ran long as well, and I only ever ripped the first season before getting the complete series set released in the US (which didn't have the same issue on any seasons), so I don't know if any of the other seasons' UK releases have this issue.
jimzdrojewski
#5 Post by jimzdrojewski » Wed Dec 22, 2021 5:26 pm
Late to the game here but just picked up the UK blu-ray set and having the same problem with season 2 as well as episode 10 of season 5. Is there any solution to this issue? Thanks!
