Can't rip Warrior UHD?
Timberflake1983
Post by Timberflake1983 »
Hi guys,
Billy kindly remotely changed the firmware on my BU40N last week from 1.04 to 1.00 and all has been well. However, I'm trying to rip Warrior UHD today and am getting the following in the log, does anyone know how to get it to work?
MakeMKV v1.15.4 win(x64-release) started
Error 'OS error - Access is denied' occurred while creating 'C:/Program Files (x86)/MakeMKV/MKB_v23_save.tgz'
Using LibreDrive mode (v06.2 id=64754CF46FCA)
File 00800.mpls was added as title #0
File 00256.mpls was added as title #1
Title 00257.mpls is equal to title 00256.mpls and was skipped
Title 00258.mpls is equal to title 00256.mpls and was skipped
Title 00259.mpls is equal to title 00256.mpls and was skipped
Title 00260.mpls is equal to title 00256.mpls and was skipped
Title 00261.mpls is equal to title 00256.mpls and was skipped
Title 00262.mpls is equal to title 00256.mpls and was skipped
Title 00263.mpls is equal to title 00256.mpls and was skipped
Title 00264.mpls is equal to title 00256.mpls and was skipped
Title 00265.mpls is equal to title 00256.mpls and was skipped
Title 00266.mpls is equal to title 00256.mpls and was skipped
Title 00267.mpls is equal to title 00256.mpls and was skipped
Title 00268.mpls is equal to title 00256.mpls and was skipped
Title 00269.mpls is equal to title 00256.mpls and was skipped
Title 00270.mpls is equal to title 00256.mpls and was skipped
Title 00271.mpls is equal to title 00256.mpls and was skipped
Title 00272.mpls is equal to title 00256.mpls and was skipped
Title 00273.mpls is equal to title 00256.mpls and was skipped
Title 00274.mpls is equal to title 00256.mpls and was skipped
Title 00275.mpls is equal to title 00256.mpls and was skipped
Title 00276.mpls is equal to title 00256.mpls and was skipped
Title 00277.mpls is equal to title 00256.mpls and was skipped
Title #00020.mpls has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.mpls(1) has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.mpls has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00055.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00038.m2ts was added as title #2
File 00039.m2ts was added as title #3
Title #00040.m2ts has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00041.m2ts was added as title #4
File 00042.m2ts was added as title #5
Title 00043.m2ts is equal to title 00256.mpls and was skipped
Title #00059.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00063.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00047.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00048.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Users/benhe/Desktop
AV synchronization issues were found in file 'Scary Movie 2_t00.mkv' (title #1)
Forced subtitles track #3 turned out to be empty and was removed from output file
Forced subtitles track #5 turned out to be empty and was removed from output file
1 titles saved
Error 'OS error - Access is denied' occurred while creating 'C:/Program Files (x86)/MakeMKV/MKB_v14_save.tgz'
File 00010.mpls was added as title #0
File 00001.mpls was added as title #1
File 00004.mpls was added as title #2
File 00015.mpls was added as title #3
Title #00000.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00019.m2ts was added as title #4
File 00001.m2ts was added as title #5
Title #00002.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00021.m2ts was added as title #6
File 00020.m2ts was added as title #7
AV synchronization issues were found in file 'Payback_t02.mkv' (title #3)
1 titles saved
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while issuing SCSI command 280..001 to device 'SPTI:\Device\CdRom0'
Re: Can't rip Warrior UHD?
Going to guess that this is the key:
Make sure you have set a MakeMKV data directory in Preferences->General that is user-writable. I use C:\MakeMKVData for mine.
Once that is done, try the rip again; MakeMKV couldn't save any information, which would have included the hash key download.
Trickyd-1
Post by Trickyd-1 »
I agree with Woodstock but the other errors look like the sleep bug and maybe need the drive resetting by powering off and on again.
Trickyd-1 wrote:
Tue Feb 09, 2021 10:17 pm
The BU40N does not have the sleep bug.
But there are quite a few strange things going on here.
Those being the key exchange that should not happen if the drive is not losing power after libredrive was uploaded to the drives ram by makemkv.
And the fail to write to the data directory I would work on that first as it may solve both.
