Mr_Orange
Re: Ultimate UHD Drives Flashing Guide Updated 2021
Post by Mr_Orange » Fri Feb 05, 2021 9:40 am
If you have posted the drive info from MakeMKV post flashing, you have not flashed 1.02MK as the drive info is showing 1.03.
nailjack
Post by nailjack » Fri Feb 05, 2021 9:48 am
yes my mistake but also with 1.02 it doesn't work
Laufwerksinformation
OS-Gerätename: N:
Aktuelles Profil: BD-ROM
Produzent: HL-DT-ST
Produkt: BD-RE WH16NS60
Revision: 1.02
Serienummer: ---------------------
Firmware-Datum: 2118-10-29 19:36
Markierungen der Bus-Verschlüsselung: 17
Highest AACS version: 72
Firmware version: 1.02
Disk-Informationen
Label: UHD_MIDWAY
Zeitstempel: 2020-01-31 11:57:40
Datenkapazität: 60.56 Gb
Disk-Typ: BD-ROM UHD
Anzahl der Layer: 2
Markierungen der Bus-Verschlüsselung: 80
nailjack
Post by nailjack » Sat Feb 06, 2021 3:14 pm
I found my mistake I forgot a hook (enable Internet access) Now everything works, thanks
but I have a question which firmware is best for the LG BH16NS55.
ASUS 3.10, LG WH16NS60 or another, I would like to burn a bluray too
Breach
Post by Breach » Sat Feb 06, 2021 3:51 pm
nailjack wrote: Sat Feb 06, 2021 3:14 pm I found my mistake I forgot a hook (enable Internet access) Now everything works, thanks
Same drive here. One of the experts here can correct me, but from I have read here and elsewhere, at least I have concluded that:
- If not using AnyDVD - WH16NS60 v1.02/v1.03 MK <- Why: prevents the sleep bug, good speeds.
- If using AnyDVD BH16NS55 v1.02/v1.03/v1.05 MK <- Why: same model firmware, works fine, and if you're using AnyDVD the sleep bug is worked around there.
I've flashed to WH16NS60 v1.03 - all works great! The ASUS one should work too, but you could have issues burning discs from what I have read.
fly_scuba
Post by fly_scuba » Mon Feb 08, 2021 8:35 pm
mm8718 wrote: Sat Jan 16, 2021 9:04 am Hi
I have the Asus BW 16D1HT and flashed it some time ago to 3.10 and i can see MKV recognising it as patched.
However for the last week or so it w ill just refuse to read any discs. last week i was able to copy Tenet in UHT and Solo a Sar Wars story - but i have tired 3 different UD disks recently Back to the future trilogy and a 1080p BluRay of Irishman but with no luck. Windows itself refuses to acknowledge the disc. The drive works and i can hear the disc spinning but it just does not register.
Has any one else seen this? I had failures before but this is 4 discs in a row!!!
Here's is my drive info:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: XXXXXXXXXX
Bus encryption flags: 1F
Highest AACS version: 76
Firmware version: 3.10
I have just experienced the exact same problem with my LG Drive that I used this forum to patch my drive : LG WH16NS40. I have been using this drive for the last 3 weeks and ripping everything from DVD to UHD 4K movies.. however, as time progressed the ability for MakeMKV to recognise a disc degraded over time. The first sign was that after a ripping session, that putting in the next disc to rip that MakeMKV reported "No disc Inserted" - then each day the ability to even recognise a disc degraded to the point where I now need to replace this drive.
MakeMKV is now reporting this drive as:
OS device name: F:
Product: BD-RE WH16NS60
Revision: 1.02
Any attention or help in either rectifying this issue with this existing drive - or an explanation of a possible reason for why it happened would be nice.. :) Thanks Guys!!
Post by Coopervid » Mon Feb 08, 2021 10:54 pm
If the drive is still covered by warranty - return it.
fly_scuba
Post by fly_scuba » Tue Feb 09, 2021 2:18 am
yes sir.. I believe that it was the best course of action.. bought at Amazon 3 weeks ago - the return was accepted with a new unit coming in exchange. I wonder if I wore out the tracking mechanism or something will all the ripping I've done..? Over 4 TB has been ripped. In any event.. I am sure that an accurate diagnosis would be difficult at best with just a description of the symptoms... I was just curious if anyone else had experienced this phenomenon.
I will need to flash the new drive after it arrives - I did it right the first time..I think I can do it again.. Same model of unit is coming..I'll use that tool that Windows 10 can use to "talk" to the firmware on the drive.. But I forgot all the steps.. I'll need to find the right guide again.. :roll:
MisterFribble
Post by MisterFribble » Tue Feb 09, 2021 2:44 am
So, I have a WH14SN40 that I just bought (February 2021). I noticed that the guide here says to flash to 1.02, but the latest mkv firmware version is 1.05 (which is the same as the firmware on my drive). Do I use the 1.02 if I want to do UHD? Also, I assume this drive is encrypted. Am I correct? Thanks.
brucehvn
Post by brucehvn » Tue Feb 09, 2021 4:10 am
MisterFribble wrote: Tue Feb 09, 2021 2:44 am So, I have a WH14SN40 that I just bought (February 2021). I noticed that the guide here says to flash to 1.02, but the latest mkv firmware version is 1.05 (which is the same as the firmware on my drive). Do I use the 1.02 if I want to do UHD? Also, I assume this drive is encrypted. Am I correct? Thanks.
I'm a newbie here, but from what I've read so far, stock firmware above 1.02 disabled the ability to rip UHD discs. That's why they say you need to downgrade it to 1.02 (again stock firmware). As far as the mkv firmware, I'm not sure about those, but I do know they are not encrypted. And yes, your 1.05 firmware is encrypted, so whatever method you use to downgrade to 1.02 or install the mkv firmware, if there's an "enc" flag, you need to make sure you pass that in. I believe both SDFTool and MakeMKVCon use that "enc" flag.
CaptCommy
Post by CaptCommy » Tue Feb 09, 2021 10:41 pm
So I've got a WH16NS40 that was originally reporting it's version as 1.03. Went through the steps in the youtube guide for encrypted firmware to flash it with the HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin from the google drive. No error messages, and MakeMKV reports it as 1.02 now, but it still says unpatched instead of the Microcode Enabled message shown in the video.
Is this something I should worry about? Is there another step I need to follow I missed?
Post by Billycar11 » Wed Feb 10, 2021 12:12 am
CaptCommy wrote: Tue Feb 09, 2021 10:41 pm So I've got a WH16NS40 that was originally reporting it's version as 1.03. Went through the steps in the youtube guide for encrypted firmware to flash it with the HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin from the google drive. No error messages, and MakeMKV reports it as 1.02 now, but it still says unpatched instead of the Microcode Enabled message shown in the video.
no but you didnt flash WH16NS60 you flashed WH16NS40 will work either way but you will have the sleep bug and slower default rip speeds
fly_scuba
Post by fly_scuba » Wed Feb 10, 2021 1:44 am
Cerus wrote: Tue Jan 12, 2021 7:42 pm Just wanted to verify that I did everything correctly when flashing my LG WH16NS40 that came with 1.05. Read tons of posts, watched the HAXOR v2 video and was still kinda confused.
So I took the easier way and used the sdftool_flasher and the mk-firmware-pack-20200720.
Ran the tool and flashed to HL-DT-ST-BD-RE_WH16NS40-NS50-1.05-NM00900-212005061440 from the "HL-DT-ST" folder with the enc option checked (after forgetting to click it the first time)
Then flashed to HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936 from the "old" folder without enc checked.
No errors and drive seems to be working fine. Is 1.02 still the best firmware to be on or should I flash to the DE 1.00 or MK 1.01? I only use MakeMKV for ripping.
Thank you for this detailed description of how you modified the firmware for the LG WH16NS40 downgraded to the 1.02 firmware so that UHD discs can be ripped. Ai appreciate your step by step process.. It worked for me tonight! :)
CaptCommy
Post by CaptCommy » Wed Feb 10, 2021 6:02 am
Billycar11 wrote: Wed Feb 10, 2021 12:12 am
Can I flash it to the proper WH16NS60 from this state to fix the sleep bug or will that cause more issues than it solves?
Post by Billycar11 » Thu Feb 11, 2021 1:30 am
CaptCommy wrote: Wed Feb 10, 2021 6:02 am
yes you can flash to WH16NS60 1.02 fine now to fix the sleepbug
Bluray_Star
Post by Bluray_Star » Thu Feb 11, 2021 8:17 pm
I try to flash my ASUS BW-16D1HT today. But it doesn't work anymore. Tt no longer recognizes a disc :( . Now I saw that it was built 2014. What can I do?
