LG WH16NS40 1.05 won't downgrade to 1.02
ivisuals
#1 Post by ivisuals » Sat Feb 06, 2021 5:47 pm
Trying to rollback my LG WH16NS40 1.05 drive to read 4K disks, but running into some issues.
I tried following the Haxor manual here using makemkvcon64.exe to flash my drive: https://www.youtube.com/watch?v=jyQV1aPlbow
with the file provided here: https://www.makemkv.com/forum/viewtopic ... 873#p70284
Flash got up to 98% and then said: "Write DRAM NG 05/26/03" and then "Command produced error code 0x8f052603"
And the flash failed, my drive is still on 1.05.
I then tried this method with the UI mode with the file "DE_flash_HL-DT-ST_BD-RE_WH14NS40_1.02_NS50.bin": https://www.youtube.com/watch?v=Yfpf6HoMMis
But then I got this error: "Write DRAM NG 05/26/03"
And my drive is still on 1.05.
Am I missing a step somewhere?
Re: LG WH16NS40 1.05 won't downgrade to 1.02
#2 Post by MartyMcNuts » Sun Feb 07, 2021 4:52 am
ivisuals wrote: Sat Feb 06, 2021 5:47 pm Trying to rollback my LG WH16NS40 1.05 drive to read 4K disks, but running into some issues.
This is happening because your stock 1.05 is an encrypted firmware. Also, you can't go directly to that firmware. My suggestion is to use the SDFtool Flasher (use the search function to find the thread) and:
1. Flash drive to WH16NS40 1.05 MK (from MK firmware folder) with "enc?" checked.
2. Once this first flash has completed, your drive no longer has encrypted firmware, so now you can flash whatever firmware you want to use (with "enc?" unchecked).
ivisuals
#3 Post by ivisuals » Sun Feb 07, 2021 6:36 pm
MartyMcNuts wrote: Sun Feb 07, 2021 4:52 am
Awesome, thank you! I was able to flash to the patched version of 1.05 and now I can read 4K blu rays in Libre Mode. Is there an advantage to switching to 1.02 or is the patched 1.05 the same?
#4 Post by MartyMcNuts » Sun Feb 07, 2021 10:59 pm
ivisuals wrote: Sun Feb 07, 2021 6:36 pm
If it's working and you are happy then leave as is. I just prefer and recommend a lower firmware as the latest one's are pretty ordinary.
datrox
#5 Post by datrox » Wed May 26, 2021 1:47 am
Hello.
I'm walking through Marty's steps outlined in this thread for my WH16NS40 v 1.05 encrypted firmware (July 2020 manufacture date), but cannot find the referenced patched firmware file WH16NS40 1.05 MK in the downloaded MK firmware pack (from the Downgrade Enabled Firmware V.2.zip file).
The only WH16NS40 files I can find in that pack are the following:
HL-DT-ST-BD-RE_WH16NS40-NS50-1.05-NM00900-212005061440.bin
HL-DT-ST-BD-RE_WH16NS40-NS50-1.03-NM00600-211711211653.bin
Are one of these two above files the modified WH16NS40 1.05 MK file? Or is there another firmware pack that I need to download to get the modified firmware for this drive?
Thanks in advance!
Paul
soloist3
#6 Post by soloist3 » Wed May 26, 2021 8:33 pm
Check the top directory (folder), it should read "MK" firmware, so all those firmware .bin's will be "MK" (patched) variants.
I literally JUST did this yesterday on my 16NS40, which was also 1.05. Used SDFtool, clicked "enc" box, and went straight to 1.03mk, worked flawlessly. Good luck :)
#7 Post by MartyMcNuts » Wed May 26, 2021 11:44 pm
datrox wrote: Wed May 26, 2021 1:47 am Hello.
Thanks in advance!
Paul
Yep, the first one.
jriggins7
#8 Post by jriggins7 » Tue Aug 01, 2023 8:31 pm
Would anyone be willing to do a one on one session to help me flash my player ? Having issues getting mine to downgrade my player to read 4k discs I have tried everything that I could find on this site. Not sure if anyone can help me? Thanks so much for your time.
#9 Post by MartyMcNuts » Wed Aug 02, 2023 4:05 am
jriggins7 wrote: Tue Aug 01, 2023 8:31 pm Would anyone be willing to do a one on one session to help me flash my player ? Having issues getting mine to downgrade my plater to read 4k discs I have tried everything that I could find on this site. Not sure if anyone can help me? Thanks so much for your time.
Show us your MakeMKV info.
jriggins7
#10 Post by jriggins7 » Wed Aug 02, 2023 1:11 pm
Hey Thanks so much for taking a look really appreciate it!
#11 Post by Billycar11 » Wed Aug 02, 2023 4:41 pm
jriggins7 wrote: Wed Aug 02, 2023 1:11 pm Hey Thanks so much for taking a look really appreciate it!
Your attachment likely did not go though just post an imgur link I think the site is out of space for image uploads
You can also embed it with the img function here but a link will do
#12 Post by Coopervid » Wed Aug 02, 2023 4:46 pm
And easier: Just copy & paste the text from your Makemkv info in your post.
jriggins7
#13 Post by jriggins7 » Wed Aug 02, 2023 5:06 pm
Hey thanks so much sorry about that.
OS device name: I:
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: KL7N52A3351
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 1.05
#14 Post by MartyMcNuts » Thu Aug 03, 2023 12:12 am
jriggins7 wrote: Wed Aug 02, 2023 5:06 pm Hey thanks so much sorry about that.
OS device name: I:
Revision: 1.05
Use SDFtool flasher and flash it to WH16NS60 1.02-MK first. You can leave it on this firmware (recommended as it is fast and removes the sleep bug) or you can now flash it to another firmware.
jriggins7
#15 Post by jriggins7 » Thu Aug 03, 2023 3:34 am
Yes that worked thank you so much!!! I’m ripping 4Ks now!
