Question: Is there any quality difference if you encode the same file in Profile 4 vs. 5? My TV only supports 4 and 5 AFAIK. I note that Profile 4 still contains an HDR10 track so I can play it anywhere, but I can only play the Profile 5 file on my TV. Is there any quality improvement in Profile 5? The filesize is the same regardless of profile, but I wonder if the TV decodes it differently.
Say.. if your TV's Internal Player can play DTDL MP4/TS, STDL MP4/TS
Which one should be given first preference?
It is also possible to add Atmos/DTS audio by extracting the audio as an MP4 file via mkvtoolnix.. so the DTDL mp4 files can also have lossless audio
I am more concerned about the Picture Quality
yes, but subtitles don't work in MP4 so , just remux with tsmuxer.deadchip12 wrote: ↑Sun Feb 07, 2021 5:50 amIs the x700 able to play mp4 files that contain DD+ ac3 dolby atmos track?
They are both the wrong profile for an HDR10 base layer so the output might not be accurate.tr000 wrote: ↑Sun Feb 07, 2021 10:45 amQuestion: Is there any quality difference if you encode the same file in Profile 4 vs. 5? My TV only supports 4 and 5 AFAIK. I note that Profile 4 still contains an HDR10 track so I can play it anywhere, but I can only play the Profile 5 file on my TV. Is there any quality improvement in Profile 5? The filesize is the same regardless of profile, but I wonder if the TV decodes it differently.
p4 is a dual-layer profile and p5 is single layer... so if the source is FEL and your TV support it, p4 will be better even if it's the wrong profile for HDR10 BL.
Thanks, I'll use Profile 4 then. I saw in the DV docs that Profile 4 is supposed to have an SDR base layer, but the Profile 4 file played on a regular HDR display looks the same to me as playing that HDR10 HEVC track by itself, so no harm done, I suppose.RESET_9999 wrote: ↑Sun Feb 07, 2021 2:39 pmThey are both the wrong profile for an HDR10 base layer so the output might not be accurate.
even external subtitles won't work?RESET_9999 wrote: ↑Sun Feb 07, 2021 2:37 pmyes, but subtitles don't work in MP4 so , just remux with tsmuxer.deadchip12 wrote: ↑Sun Feb 07, 2021 5:50 amIs the x700 able to play mp4 files that contain DD+ ac3 dolby atmos track?
I don't know... I never tried. I use TS container for everything that is DV.
Why TS over m2ts?RESET_9999 wrote: ↑Sun Feb 07, 2021 5:55 pmI don't know... I never tried. I use TS container for everything that is DV.
no particular reason. It's just the default tsMuxer output.
Hi I have read a lot about how to get Dolby Vision with FEL to play on my LG CX. It seems like the internal player of LG CX can only play Dolby Vision with MEL and not FEL is this true? Also what filetypes can it play, can the LG CX play mkv with Dolby Vision MEL? Will the LG CX’s internal player never be able to play Dolby vision with FEL?
If the internal player is not the way to go would I have to get the x700 to play Dolby Vision with FEL, or could some of these chinese oppo clones do it? Which one should I get, would the M9702 v3 be able to play Dolby Vision FEL with lossless audio? I saw one that costs 50 dollars on ebay is this legit? Where can I see what devices play Dolby Vision with FEL and the filetypes supported?
I’m new to the scene and just got my LG CX a few weeks ago would really appericiate if somebody could answer my questions. I feel like it is so hard to get information on this stuff compared to other tech stuff. There is just this and avforums that talk about it
I don't know where you're getting your info from, but there have been no reports of the ubk90 being able to play dual layer files from any format outside of mp4, meaning it cannot do DL DV + lossless audio unless you're playing the physical disk. If you're reporting this info yourself from personal experience, then that's good news to the rest of us. The only devices that is confirmed capable of playing DL FEL DV + lossless audio is the x700/x800m2 (dual track m2ts/ts format) and the oppo 203/205 and its clones (bdmv/iso). And no, you will not find the oppo clones on ebay, especially not for under $300.
Like I said, the x700 can only play them in m2ts/ts containers. There are no devices out there at the moment that can play FEL DV in mkvs with full accuracy.
I have a Sony ubp-x700 player. Can someone explain how I can use that to play DV MT2S files? Do I have to copy them to USB or can I access files on my NAS? Cheers.
