tr000
#4396 Post by tr000 » Sun Feb 07, 2021 10:45 am
Question: Is there any quality difference if you encode the same file in Profile 4 vs. 5? My TV only supports 4 and 5 AFAIK. I note that Profile 4 still contains an HDR10 track so I can play it anywhere, but I can only play the Profile 5 file on my TV. Is there any quality improvement in Profile 5? The filesize is the same regardless of profile, but I wonder if the TV decodes it differently.
Ride_UL
#4397 Post by Ride_UL » Sun Feb 07, 2021 12:04 pm
Say.. if your TV's Internal Player can play DTDL MP4/TS, STDL MP4/TS
Which one should be given first preference?
It is also possible to add Atmos/DTS audio by extracting the audio as an MP4 file via mkvtoolnix.. so the DTDL mp4 files can also have lossless audio
I am more concerned about the Picture Quality
#4398 Post by RESET_9999 » Sun Feb 07, 2021 2:37 pm
deadchip12 wrote:
Sun Feb 07, 2021 5:50 am
Is the x700 able to play mp4 files that contain DD+ ac3 dolby atmos track?
yes, but subtitles don't work in MP4 so , just remux with tsmuxer.
#4399 Post by RESET_9999 » Sun Feb 07, 2021 2:39 pm
They are both the wrong profile for an HDR10 base layer so the output might not be accurate.
p4 is a dual-layer profile and p5 is single layer... so if the source is FEL and your TV support it, p4 will be better even if it's the wrong profile for HDR10 BL.
tr000
#4400 Post by tr000 » Sun Feb 07, 2021 4:10 pm
Thanks, I'll use Profile 4 then. I saw in the DV docs that Profile 4 is supposed to have an SDR base layer, but the Profile 4 file played on a regular HDR display looks the same to me as playing that HDR10 HEVC track by itself, so no harm done, I suppose.
deadchip12
#4401 Post by deadchip12 » Sun Feb 07, 2021 4:51 pm
even external subtitles won't work?
#4402 Post by RESET_9999 » Sun Feb 07, 2021 5:55 pm
I don't know... I never tried. I use TS container for everything that is DV.
glc650
#4403 Post by glc650 » Sun Feb 07, 2021 11:56 pm
Why TS over m2ts?
#4404 Post by RESET_9999 » Mon Feb 08, 2021 12:28 am
Why TS over m2ts?
no particular reason. It's just the default tsMuxer output.
daddy
#4405 Post by daddy » Thu Feb 11, 2021 6:32 am
External subtitles works in mp4.
You just have to name the srt file exactly like the mp4 file.
SeaZe
#4406 Post by SeaZe » Fri Feb 12, 2021 2:04 am
Hi I have read a lot about how to get Dolby Vision with FEL to play on my LG CX. It seems like the internal player of LG CX can only play Dolby Vision with MEL and not FEL is this true? Also what filetypes can it play, can the LG CX play mkv with Dolby Vision MEL? Will the LG CX’s internal player never be able to play Dolby vision with FEL?
If the internal player is not the way to go would I have to get the x700 to play Dolby Vision with FEL, or could some of these chinese oppo clones do it? Which one should I get, would the M9702 v3 be able to play Dolby Vision FEL with lossless audio? I saw one that costs 50 dollars on ebay is this legit? Where can I see what devices play Dolby Vision with FEL and the filetypes supported?
I’m new to the scene and just got my LG CX a few weeks ago would really appericiate if somebody could answer my questions. I feel like it is so hard to get information on this stuff compared to other tech stuff. There is just this and avforums that talk about it
#4407 Post by shawnc22 » Fri Feb 12, 2021 7:56 pm
galarond wrote:
Fri Feb 12, 2021 6:48 pm
Im been reading for almost months now about this and the best choice is the lg ubk90 bluray player and use your external drive there, only till 2tb, it plays everything fine,but no isos or bluray rip carpets,so mkv, mp4, single dual layer all fine.
I don't know where you're getting your info from, but there have been no reports of the ubk90 being able to play dual layer files from any format outside of mp4, meaning it cannot do DL DV + lossless audio unless you're playing the physical disk. If you're reporting this info yourself from personal experience, then that's good news to the rest of us. The only devices that is confirmed capable of playing DL FEL DV + lossless audio is the x700/x800m2 (dual track m2ts/ts format) and the oppo 203/205 and its clones (bdmv/iso). And no, you will not find the oppo clones on ebay, especially not for under $300.
#4408 Post by shawnc22 » Sun Feb 14, 2021 4:57 am
galarond wrote:
Sun Feb 14, 2021 4:17 am
As i read the x700 cant reproduce the new mkv dolby vision movies, the dual layer ones, or the dual layers mixed in 1 video file inside the mkv, im i wrong?
Like I said, the x700 can only play them in m2ts/ts containers. There are no devices out there at the moment that can play FEL DV in mkvs with full accuracy.
tr000
#4409 Post by tr000 » Sun Feb 14, 2021 10:19 am
In general, yes, though some software has limited or no support for external .SRT files on .MP4 files (e.g., Windows Media Server).
blenky
#4410 Post by blenky » Sun Feb 14, 2021 11:09 pm
I have a Sony ubp-x700 player. Can someone explain how I can use that to play DV MT2S files? Do I have to copy them to USB or can I access files on my NAS? Cheers.
