ASUS BW-12D1S-U
forseer
ASUS BW-12D1S-U
Post by forseer » Sat Jan 04, 2020 10:17 pm
Is it possible to upgrade the firmware of an ASUS BW-12D1S-U to rip UHD disks?
Thanks in advance.
OS device name: E:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
Serial number: OLDL072395WL
Firmware date: 2013-09-10
Highest AACS version: 66
Status: Might be supported in future, keep fingers crossed
Drive platform: Pioneer RS8600
Firmware version: ID44
Re: ASUS BW-12D1S-U
Post by Woodstock » Sat Jan 04, 2020 10:37 pm
No, that drive is incapable of reading UHD - it's too old.
But, there is a possibility that it can act as a LibreDrive in the future... Hence the notation about "Status: Might be supported in future, keep fingers crossed".
LD does not imply UHD capability; it means that the drive can be told to ignore software restrictions. UHD requires hardware capable of reading the higher density data.
forseer
Re: ASUS BW-12D1S-U
Post by forseer » Sat Jan 04, 2020 11:15 pm
Thank you for the information.
danevil
Re: ASUS BW-12D1S-U
Post by danevil » Sat Feb 06, 2021 2:27 pm
I am confused, because I have the same drive and on the front of the tray that slides out it says M-DISC LG UltraHD Blu-ray.
Re: ASUS BW-12D1S-U
Post by Woodstock » Sat Feb 06, 2021 2:33 pm
What does MakeMKV say in the LibreDrive section of the info window?
danevil
Re: ASUS BW-12D1S-U
Post by danevil » Sat Feb 06, 2021 2:52 pm
I'm not sure what that means, in the Info section it says the following:
OS device name: H:
Product: BD-RE WH16NS60
Revision: MgBI9IC0035
Firmware date: 2117-11-20 20:00
Highest AACS version: 63
I am a computer idiot ;) so please bear with me, and thank you for being helpful!
danevil
Re: ASUS BW-12D1S-U
Post by danevil » Sat Feb 06, 2021 10:10 pm
I just updated MakeMKV and now it says
Hardware support: Yes
Firmware support: No
Firmware version: 1.01
