Pibben
Post
by Pibben » Tue Dec 22, 2020 9:56 am
My flashing seemed to fail half way trough:
$ makemkvcon f -d /dev/sr0 rawflash -i mk-firmware-pack-20200720/MK/ASUS/BC-12D2HT/ASUS-BC-12D2HT-3.11-WM00300-211902271319.bin
Reading input file mk-firmware-pack-20200720/MK/ASUS/BC-12D2HT/ASUS-BC-12D2HT-3.11-WM00300-211902271319.bin
Current Drive ID: ASUS_BC-12D2HT_1.00_211306141200_K9FF5M94740
yes
49% ........................
Write DRAM NG 02/04/08
Command produced error code 0x8f020408
The drive no doesn't even open or close. I tried restoring the old dumped FW:
$ makemkvcon f -d /dev/sr0 flash -i ~/dump_full_ASUS_BC-12D2HT_1.00_211306141200_K9FF5M94740.bin
No drive tool logic found in SDF.bin
Internal error 0x8d000000
Any idea on how to resolve this? Thanks!
nailjack
Post
by nailjack » Wed Feb 03, 2021 12:57 pm
Hi
I have an Asus BC-12D2HT with no firmware (only boot mode) it is before 2015, I've already searched everything but I can't find any firmware for it, maybe someone here has something for it.
Thank you
Post
by Billycar11 » Wed Feb 03, 2021 1:36 pm
nailjack wrote: Wed Feb 03, 2021 12:57 pm
Hi
Thank you
Read this and follow all the reply's follow the same steps
https://www.makemkv.com/forum/viewtopic ... 15#p104021
nailjack
Post
by nailjack » Wed Feb 03, 2021 2:47 pm
Billycar11 wrote: Mon Jan 18, 2021 11:10 pm
Ok here's a summary of what you need to do
Try the recovery option in sdf tool if that fails do this:
Downgrade your drive to WH16NS60 1.00 with sdftool or makemkv command line
Full shutdown pull power plug or flip switch push power button for 10 seconds
Then reflash WH16NS60 1.00 again with the unlocked lg or Asus flasher
Then boot in to your dosflash bottable and dump the firmware
Use the transfer tool to your correct firmware and flash it.
ok,
1. why WH16NS60 1.00 thats LG not Asus ?
2. where can I find them WH16NS60 1.00
3. last (correct firmware and flash it) I don't have that
Post
by dcoke22 » Wed Feb 03, 2021 11:53 pm
nailjack wrote: Wed Feb 03, 2021 2:47 pm
The innards are the same; there are more brands of drives than there are manufacturers.
You can find the firmware linked from the UHD Drive Guide.
nailjack
Post
by nailjack » Thu Feb 04, 2021 3:21 pm
hi,
the sdftoolflasher 1.20 not working i selcet the firmware and click start nothing.
In Makemkv tool this.
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d N: rawflash enc -i P:\Programs\AsusFirmware\LG\DE_LGWH16NS60_1.00.bin
I run the Windows powershell as Admin
nailjack
Post
by nailjack » Thu Feb 04, 2021 10:02 pm
i thing this drive is in a Emergency-Mode
Asus ASUS BC-12D2HT_Boot
Post
by Billycar11 » Thu Feb 04, 2021 10:47 pm
nailjack wrote: Thu Feb 04, 2021 3:21 pm
hi,
Update makemkv if you not on the latest version
nailjack
Post
by nailjack » Fri Feb 05, 2021 7:57 am
last version is install 1.15.4
nailjack
Post
by nailjack » Sat Feb 06, 2021 3:03 pm
nope not working.
I copied the file into the .\MAKEMKV folder then started MakeMKV and then Powershell as admin and enter this .\makemkvcon64.exe f --all-yes -d D: rawflash enc -i E:\Programs\AsusFirmware\LG\DE_LGWH16NS60_1.00.bin
and that is the result
PS C:\Program Files(x86)\MakeMKV>.\Makemkvcon64.exe f --all-yes -d D: rawflash enc -i E: \Programs\AsusFirmware\LG\DE_LGWH16NS60_1.00.bin
PS C: \Program Files(x86)\MakeMKV>
here a log file
Debug log started at Thu Feb 06 15:24:57 2021, written by MakeMKV v1.15.4 win (x64-release)
001005: 0000 MakeMKV v1.15.4 win (x64 release) started
001004: 0000 Debug recording switched on. The recording is saved as file: // C:\Users\Server/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.72.0 / Schannel / 1.41.0 (x86_64-pc-win32), proxy server not set.
No SDF v07d: ASUS_BC-12D2HT_BOOT
DEBUG: Code 3 at l36L! T.ju1-I5hQj <x_ & C <| l: 29395310
SDF id v07d: ASUS_BC-12D2HT_BOOT
Post
by Billycar11 » Sat Feb 06, 2021 10:00 pm
As I said open the makemkv gui before trying to flash again the sdf file should disappear in the directory then try again
nailjack
Post
by nailjack » Sun Feb 07, 2021 2:40 am
it´s all not working
i put the sdf.bin in .\makemkv folder, start makemkv the sdf.bin is goes to _private_data.tar !?!
now i started powershell ? then i use this .\Makemkvcon64.exe f --all-yes -d D: rawflash enc -i E: \Programs\AsusFirmware\LG\DE_LGWH16NS60_1.00.bin
then
I do not know how to continue
