Antidisturbios TV Series
aidalai
Post by aidalai »
Hi there.
Im having problems trying to extract the mkv from this blurays with the last released version.
Thats the problem I found.
Re: Antidisturbios TV Series
Your optical drive is probably having trouble reading the disc because it is dirty. The standard advice here is to clean your disc. My preferred method is to use warm water and dish soap to gently clean away any oils on the surface. There are other methods as well.
aidalai
Post by aidalai »
Its not directly from bluray, its from an image at the HDD
I don't think MakeMKV is lying to you. There's something wrong with 00009.m2ts. Refresh your copy from a backup or rip the disc again.
aidalai
Post by aidalai »
dcoke22 wrote:
Thu Feb 04, 2021 10:23 pm
Theres no problem with 00009.m2ts cause its only one of the chapters. If I do the same with other chapter, the program say there are same errores with 00007.m2ts or 00005.m2ts...
aidalai wrote:
Thu Feb 04, 2021 11:30 pm
how did you make the image backup?
maybe you did it with a program that does not tell you about the errors.
should have done it with makemkv folder backup just redo it that way
