https://forum.kodi.tv/showthread.php?tid=360018DolbyVisionFTW wrote: ↑Tue Feb 02, 2021 9:48 pmThanks for replying. Any recommended custom builds of kodi I should look at, please?DaMacFunkin wrote: ↑Tue Feb 02, 2021 9:07 pmCustom builds of Kodi are the best way to go on shield Plex is currently shit.DolbyVisionFTW wrote: ↑Tue Feb 02, 2021 2:54 pmHi.
What app options are there for Dolby Vision playback via a Nvidia Shield TV Pro (2019) on a Panasonic GZ950 OLED? I’ve read some mention Plex beta app, is that currently the only option?
Thanks.
DaMacFunkin
deadchip12
Say I use the x700 to play dolby vision m2ts file, but I want audio from my pc since I use headphone and virtual surround software instead of speakers. Is there a way to sync the video output from the x700 and the audio output from my pc instead of manually doing so which is a PITA each time?
Unfortunately like the previous poster said, you're never going to get real DV from UHD rips on an AppleTV. The main issue is that the hardware is only capable of profile 5 DV, which is single layer and in a different color space from the profile 7 found on UHD disks. So even if you have an MEL title that you can safely convert to single layer, you're still likely to have color accuracy issues to the lack of a color space conversion between the different profiles. With tsMuxer, you can alter the source code (there are also compiled versions floating around) so that instead of spitting out profile 8 for single layer files, it would produce profile 5 files. People have used this for their ATV, but like I said, there are likely to be color issues.HarperVision wrote: ↑Tue Feb 02, 2021 7:56 pmYes that can be tricky so I always make sure I check the HDfury web GUI to see what is being sent. I’m the one who discovered the HDFury LLDV/Dolby Vision hack for HDR only displays/projectors and shared it with the world, so I know this well and check It often.
So the answer is, Infuse Pro only plays the HDR base layer of the DV rip so I’m only getting HDR10 and no DV, correct?
I do like the results of it with Dolby Vision forced on with Match Dynamic Range set to off. The AppleTV 4K does an exemplary job of mapping it to pseudo Dolby Vision but I’d love to feed it real DV if at all possible of course!
https://www.avsforum.com/threads/dune-h ... 599/page-2RESET_9999 wrote: ↑Fri Jan 29, 2021 11:00 pmDV could be only supported for Streaming apps....
I really hope it supports dual-layer FEL + lossless audio with PLEX. If it does, I think I'm going to buy one.
early reports does seem promising
YESshawnc22 wrote: ↑Wed Feb 03, 2021 6:00 pmhttps://www.avsforum.com/threads/dune-h ... 599/page-2RESET_9999 wrote: ↑Fri Jan 29, 2021 11:00 pmDV could be only supported for Streaming apps....
New it.
That’s great!!
Hopefully Now new improvements on ripping method might have to change.
oh, that is nice..
now Manix please do a small capture to verify the colors.
please also try DV MKV playback
-Hi there:
Could you provide me with the links to the latest version of
-python
-mp4muxer
and the one that brings everything incorporated including FFmpeg (The version that a user made that brings everything together.)
Thank you very much.
-Greetings to Crodiales.
-python
-mp4muxer
My PUS7304 (a TV with android) has the same problem when I play a FEL movie converted to mp4 with dvdfab, but If I play a MEL movie It fixes. If you use yusesope FEL to MEL tool that doesn't happen.RESET_9999 wrote: ↑Fri Jan 29, 2021 5:22 pmyeah, the TS/M2TS files created by tsMuxer have a bug.kws53 wrote: ↑Fri Jan 29, 2021 5:17 pmThanks. So - Latest TSMuxer release (JustDan) is the perfect way to go creating DT DL P7.
Final question - your signature refers to a .TS file from DolbyLabs (I downloaded) and you refer to it "fixing" a DL problem on the x700? I'm confused based on what you say above...
When you stop playback of a DT-DL TS file, the next file you play will have a green or purple tint on it. The x700 and the Oppo somehow get locked in that mode and only(besides rebooting) playing the TS demo file in my signature will unlock the player. I think playing back an original UHD-BD should unlock the player as well.
Hi,RESET_9999 wrote: ↑Wed Feb 03, 2021 7:02 pmoh, that is nice..
Can you create a working DTDL ISO file for this guy?
https://www.avsforum.com/threads/dune-h ... t-60477087
I tried to do it with tsmuxer from the dtdl mp4 file, but it only plays in lite mode on Dune.
Hi, you can try the ISO I made for the mkvtoolnix guy when they implemented DV in mastroka.NiCE77 wrote: ↑Sat Feb 06, 2021 8:58 amHi,
https://drive.google.com/file/d/1HeooI- ... sp=sharing
but didn't they already test DV ISO playback?
Thanks, but I need the same FEL test video like this, but in ISO: https://www.makemkv.com/forum/viewtopic ... 00#p104113RESET_9999 wrote: ↑Sat Feb 06, 2021 2:58 pmHi, you can try the ISO I made for the mkvtoolnix guy when they implemented DV in mastroka.NiCE77 wrote: ↑Sat Feb 06, 2021 8:58 amHi,
ha I see.NiCE77 wrote: ↑Sat Feb 06, 2021 7:25 pm
since you already tried to remux it with tsmuxer, there's nothing more I can do.
So I assume my fel test mp4 does not play on the Dune player? Maybe it just doesn't support FEL after all because the sample works on fel capable devices( x700 and C8). they should try a genuine DL MEL mp4
it's still early but the Dune does not look promising anymore for FEL support.
deadchip12
Is the x700 able to play mp4 files that contain DD+ ac3 dolby atmos track?
This is the result on Dune:RESET_9999 wrote: ↑Sat Feb 06, 2021 9:47 pmha I see.NiCE77 wrote: ↑Sat Feb 06, 2021 7:25 pm
- 'test DT DL FEL.iso' (remux with tsmuxer from DTDL mp4) plays fine in HDR if you use the 'Play (Lite)' option. If you use 'Play (Menu)', as in full menu options, the image is very jittery and pixelated, but switch the output to DV!
- 'test DT DL FEL.mp4' plays, switch the output to DV, however just looks like white noise on screen.
- 'test ST DL FEL.mp4' plays as HDR.
- 'test SL P8 RPU.ts' plays as DV.
But all of original, untouched FEL/MEL DTDL ISO files plays fine as DV!
This german post is about that: https://www.android-mediaplayer.de/foru ... post128151
Question: Is there any quality difference if you encode the same file in Profile 4 vs. 5? My TV only supports 4 and 5 AFAIK. I note that Profile 4 still contains an HDR10 track so I can play it anywhere, but I can only play the Profile 5 file on my TV. Is there any quality improvement in Profile 5? The filesize is the same regardless of profile, but I wonder if the TV decodes it differently.
