BU40N not reading all discs
Skyterix
Post by Skyterix » Wed Feb 03, 2021 7:06 pm
I've recently got a used BU40N which I flashed with a 1.03MK and then to 1.04MK. And its behaving weird. I tried some random blueray disc I found lying around and it works 30GB is normally read and I can rip it. But then I tried Zootopia disc both 1080p and 4K and drive is not even registering a disc calming that no disc is inserted.
I tried downgrading to 1.01MK already but it's the same problem. It can't be a laser right? It's reading another blueray normally. And its not only UHD since it can't read other disc too.
I should probably note that I am using this drive in some old laptop I found lying around since I don't have an USB adapter yet. Can it be some power issue?
Do anyone has any ideas what the cause could be?
nebl78
Re: BU40N not reading all discs
Post by nebl78 » Sun Feb 07, 2021 1:58 pm
I have the same problems with an archgon bu40n firmware 1.00.
Drive is 2 days old
Have 3 different UHD disks always tried error read between 20 and 30 GB.
UHD Movies:
Tenet
King Arthur
Justice League
Also tried several platforms.
Windows 10
Big Sur MacOS
but only the MKV software 1.15.4
Blue ray HD all work
nebl78
Post by nebl78 » Sun Feb 07, 2021 2:00 pm
I also set the disk speed to code "0 = 8"
set but unfortunately exactly the same mistakes.
Post by MartyMcNuts » Sun Feb 07, 2021 11:19 pm
nebl78 wrote: Sun Feb 07, 2021 1:58 pm I have the same problems with an archgon bu40n firmware 1.00.
Drive is 2 days old
UHD Movies:
Tenet
King Arthur
Justice League
Windows 10
Big Sur MacOS
Are you connecting both USB's on the y-cable? or using the USB-C cable?
Also, try rolling MakeMKV back to v1.15.2
nebl78
Post by nebl78 » Mon Feb 08, 2021 6:50 am
The L drive remains off with both USB connections of the Y-cable. I don't have USB-C for testing.
Version 1.15.2 same problems as with version 1.15.4
These errors came with Tenet 4K:
Failed to save title 1 to file /Users/punisher/Movies/Tenet/Tenet_t01.mkv
Encountered 18 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failed
Using LibreDrive mode (v06.2 id=64754CF46FCA)
Title #00053.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00141.mpls was added as title #0
File 00800.mpls was added as title #1
File 00055.mpls was added as title #2
Title 00121.mpls is equal to title 00141.mpls and was skipped
Title #00054.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00004.m2ts was added as title #3
File 00009.m2ts was added as title #4
Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00015.m2ts was added as title #5
Title #00002.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/punisher/Movies/JUSTICE_LEAGUE
nebl78
Post by nebl78 » Mon Feb 08, 2021 4:39 pm
All good.
It was just the discs.
Today Tenet exchanged a new disk ran without problems.
UHD disks are very sensitive.
