Hi guys,
I'm looking to replace my old Corsair 200r case and am looking at something without a 5.25" drive as my need for a blu ray drive is decreasing, but I'd still like to have the option.
Can anyone recommend an external blu ray reader for use with MakeMKV? Ideally is would be usb powered.
Looking for an external blu ray drive
Timberflake1983
Re: Looking for an external blu ray drive
BU40N USB
Timberflake1983
Thanks for that.....bought it and it doesn't work......shows up on the computer fine, but it MakeMKV it just says "The program can't find any usable optical drives."......waste of £85
Run as admin add to defender ransomware white list.Timberflake1983 wrote: ↑Wed Feb 03, 2021 11:04 amThanks for that.....bought it and it doesn't work......shows up on the computer fine, but it MakeMKV it just says "The program can't find any usable optical drives."......waste of £85
Many things can cause this take some time to figure it out and it will be $85 well spent
Timberflake1983
I think I may have jumped the gun....my enclosure arrived and it seems to now be working, although I've only got one disc to hand (Seven Worlds One Planet).
It's on firmware v1.04, is this ok or will it need flashing? And if so how do I do that?
It will need to be flash for uhd read my guide or email me for an automated self flash kit.Timberflake1983 wrote: ↑Wed Feb 03, 2021 5:02 pmI think I may have jumped the gun....my enclosure arrived and it seems to now be working, although I've only got one disc to hand (Seven Worlds One Planet).
