makemkvcon appears to be ignoring .MakeMKV/settings.conf
salernost
Post by salernost »
I am using makmkvcon for a headless ripper found at docker hub at: rix1337/docker-ripper
This docker doesn't include the ccextractor, so I receive the common error:
"Unable to execute external program 'ccextractor' as its path is not set in preferences"
Therefor, I installed ccextractor, and added to .MakeMKV/settings.conf:
app_ccextractor = "/usr/local/bin/ccextractor"
I still receive the
it appears to completely ignore the settings file?
felix_bellator42
Re: makemkvcon appears to be ignoring .MakeMKV/settings.conf
Post by felix_bellator42 »
I found since I need to run makemkvcon using sudo because of some permissions issue I have not figured out yet, the putting the settings.conf file in /root/.MakeMKV/ directory solved the issue of the executable finding the license key.
