Someone I know is having this issue:
"LibreDrive compatible drive is required to open this disc - video can't be decrypted.
Backup failed"
But as you can see from the screenshot, the drive is LibreDrive enabled.
The next disc he tried, he got:
"The volume key is unknown for this disc - video can't be decrypted
Backup failed"
Any idea what could be up?
EDIT: He just told me he didn't try restarting his system, so I asked him to do that. And of course, it works as expected now. Sorry for the wild goose chase, and thanks for all responses.
"LibreDrive compatible drive is required..." [solved]
fitbrit
Re: "LibreDrive compatible drive is required..." but this IS a LibreDrive enabled drive
Did he send the .tgz file created to svq@makemkv.com so that it can be processed?
Have you got "Allow access to server" checked in preferences? MakeMKV needs internet access to be able to download the hashed keys.fitbrit wrote: Tue Feb 02, 2021 12:30 am Someone I know is having this issue:
Backup failed"
Backup failed"
EDIT: He just told me he didn't try restarting his system, so I am asking him to do that. If it works, I'll delete the post. If it doesn't, I'll delete the edit.
I don't think that drive is LibreDrive enabled, according to the screen shot. It certainly can be, but it currently isn't. It if was enabled, the 'Firmware type:' line would say Patched (microcode access re-enabled) instead of Original (unpatched).fitbrit wrote: Tue Feb 02, 2021 12:30 am "LibreDrive compatible drive is required to open this disc - video can't be decrypted.
Backup failed"
No, the original WH16NS40 1.02 firmware is already LD enabled. Just like the original BH16NS55 1.02 is LD enabled. There are quite a few original unpatched firmwares that are LD enabled.dcoke22 wrote: Tue Feb 02, 2021 6:06 amI don't think that drive is LibreDrive enabled, according to the screen shot. It certainly can be, but it currently isn't. It if was enabled, the 'Firmware type:' line would say Patched (microcode access re-enabled) instead of Original (unpatched).fitbrit wrote: Tue Feb 02, 2021 12:30 am "LibreDrive compatible drive is required to open this disc - video can't be decrypted.
Backup failed"
fitbrit
Thanks all. A simple restart fixed the issue, and I apologise that I didn't ensure he did this first.
