BRUHD-PU3-PK BU12 to BU10?
Seel68
Post by Seel68 »
Hi, I bought BRUHD-PU3-BK in Japan. its FW is BU12.
And I'm going to try to downgrade it, but I'm afraid it's right.
1. Use ASUS Flasher with HL-DT-ST-BD-RE_BU40N-BU12-OM01001-211902230922.bin(BU40N-B-Japan-Buffalo folder).
(Or with HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142(BU40N-N-Main folder)? Confused..)
2. Flash it again with DE_Buffalo_BRUHD-PU3_BU10.
* At first, I tried to downgrade it without MK(only with DE_Buffalo_BRUHD-PU3_BU10), but failure #4 popped up. :(
Please make sure it's correct.
Re: BRUHD-PU3-PK BU12 to BU10?
Seel68 wrote: Wed Oct 28, 2020 8:11 am Hi, I bought BRUHD-PU3-BK in Japan. its FW is BU12.
1. HL-DT-ST-BD-RE_BU40N-BU12-OM01001-211902230922.bin
2. DE_Buffalo_BRUHD-PU3_BU10 OR DE_LG_BU40N_1.00
Seel68
Post by Seel68 »
MartyMcNuts wrote: Thu Oct 29, 2020 12:07 am
It worked! I can play my UHD Blu-ray now! :D
God bless you. I truly appreciate that!
jesperb
Post by jesperb »
This worked for me as well.
Many, many, many, many thanks for all of your hard work.
gfliger51
Post by gfliger51 »
I have the same drive setup as Seel68. I haven't been able to flash it as I can't get the ASUS flasher (ASUS_ODD_FW_Changer_(Modified) (24.8.2019) to work for some reason. Every time I try to run it it will open but automatically closes after about 10 seconds. Then, after about another 10 seconds or so, it will completely disappear from my system as though I deleted the file. I have to extract another copy from the downloaded .zip file. Doesn't matter how many times I extract and try to run the file, the same thing happens. How do I get around this? All suggestions are appreciated.
Post by d00zah »
gfliger51 wrote: Sat Mar 13, 2021 6:37 pm Every time I try to run it it will open but automatically closes after about 10 seconds. Then, after about another 10 seconds or so, it will completely disappear from my system as though I deleted the file. I have to extract another copy from the downloaded .zip file.
That sounds like an anti-virus/malware app stopping a questionable file execution, & deleting/quarantining the offending file. If you run such protection, check detection logs.
Or, try this instead... SDFtool Flasher
gfliger51
Post by gfliger51 »
Turns out you're exactly right. My anti-virus program was quaranteeing the file every time I ran it and was not informing me that it was doing it. I added the program to the real-time scanning exception list and it ran fine. Did both the recommended flashes and now I can process UHD discs.
Thanks for jogging my brain. I should have realized that right off the bat.
shinkiro
Post by shinkiro »
Hi guys, I just got the same Japanese drive "BRUHD-PU3" (external) but I don't know which tool or firmware to use to read UHD blu-ray discs.
Do I use the flasher on this thread: viewtopic.php?f=16&t=22896 or something else entirely?
I saw that "MartyMcNuts" said to use "1. HL-DT-ST-BD-RE_BU40N-BU12-OM01001-211902230922.bin
2. DE_Buffalo_BRUHD-PU3_BU10 OR DE_LG_BU40N_1.00", so any of these three firmwares work?
