LG BH16NS55 + ICY BOX. Keeps disconnecting/reconnnecting
knud321
#1 Post by knud321 » Mon Feb 01, 2021 4:29 pm
So I bought yesterday LG BH16NS55 and RaidSonic ICY BOX IB-550StU3S. I flashed it to BD-RE WH16NS60 patch 1.02 It worked perfectly no issues all day.
But now it keeps connecting/disconnecting every other second.
Any suggestions on what to do?
Re: LG BH16NS55 + ICY BOX. Keeps disconnecting/reconnnecting
#2 Post by Woodstock » Mon Feb 01, 2021 4:32 pm
That would probably be an Icybox issue. Unplug it from the drive; does the OS still connect/disconnect from the USB device?
knud321
#3 Post by knud321 » Mon Feb 01, 2021 4:36 pm
It has been running for 5 minutes now without the drive. No discconnects yet.
#4 Post by Woodstock » Mon Feb 01, 2021 5:59 pm
Is the Icybox powering the drive from its own power supply?
Digging in to some of the reviews, people have had issues with the power supply being flaky. Try to actually do anything with the optical drive, and the unit would shut down completely. Change to a different power supply, and the issues went away.
knud321
#5 Post by knud321 » Mon Feb 01, 2021 6:39 pm
It is using Icy box power adapter. Now I'm trying your advice with a different adapter. Testing right now.
#6 Post by Coopervid » Mon Feb 01, 2021 9:04 pm
I had disconnecting errors in the past with USB PCI cards with VIA chips. Had to replace the cards with Renesas chips to get rid of them. So please check the ICY with another PC or Laptop to check if the USB path is the root cause.
knud321
#7 Post by knud321 » Tue Feb 02, 2021 7:43 am
How will i be able to determine if it is an icy box fault?
knud321
#8 Post by knud321 » Tue Feb 02, 2021 11:27 am
Update:
I have now been ripping 4-5 of my blurays successfully. The issue seems to be happening with a few blurays and most of my 4k blurays.
knud321
#9 Post by knud321 » Wed Feb 03, 2021 10:43 am
New update again :D
I finally figured it out. The problem was with my USB-controller driver.
So I went into device manager removed the driver for both my USB-controllers, and restarted my pc. I also ran the usb connection from the ICY BOX through my USB 3.0 to USB-C adapter.
That did the job for me, now I'm having no issues at all.
Thanks for the advises!
