If you will be using MakeMKV (not anyDVD or DVDFab) then flash WH16NS60 1.02 MK from the "old"folder in MK firmware pack with "enc?" checked.EncryptedEggs wrote: ↑Fri Jan 29, 2021 9:43 pmfirmware.png
Ok trying now to figure out which firmware I should choose for my WH16NS40. I have the mk-firmware-pack-20200720 downloaded.
If you will be using either DVDFab or AnyDVD then I would suggest perhaps DE_LG_WH16NS40_1.02 or DE_ASUS_BW-16D1HT_3.02. To do this, follow the below steps:
1. Flash WH16NS40 1.05 MK from MK firmware pack with "enc?" checked.
2. Flash either DE firmware from the DE firmware pack (located in first post of this thread) without "enc?"checked.
