Calculated BUP offset for VTS #0 does not match one in IFO header.
wavesounds
#1 Post by wavesounds » Sat Jan 30, 2021 4:24 am
Trying to read a simple DVD after flashing, failed to open disc, BUP offset error, thoughts? Drive is flashed.
Screenshot 2021-01-29 202304.jpg (100.23 KiB) Viewed 8813 times
Re: Calculated BUP offset for VTS #0 does not match one in IFO header.
#2 Post by Billycar11 » Sat Jan 30, 2021 4:33 am
wavesounds wrote: Sat Jan 30, 2021 4:24 am Trying to read a simple DVD after flashing, failed to open disc, BUP offset error, thoughts? Drive is flashed.
probably noting to do with the flash did the dvd work before?
i would just try another disc
wavesounds
#3 Post by wavesounds » Sat Jan 30, 2021 7:22 pm
Thanks, i'll keep an eye out for if it continues with other discs
