Calculated BUP offset for VTS #0 does not match one in IFO header.
wavesounds
Post by wavesounds »
Trying to read a simple DVD after flashing, failed to open disc, BUP offset error, thoughts? Drive is flashed.
Screenshot 2021-01-29 202304.jpg (100.23 KiB) Viewed 8923 times
Re: Calculated BUP offset for VTS #0 does not match one in IFO header.
wavesounds wrote: Sat Jan 30, 2021 4:24 am Trying to read a simple DVD after flashing, failed to open disc, BUP offset error, thoughts? Drive is flashed.
probably noting to do with the flash did the dvd work before?
i would just try another disc
wavesounds
Thanks, i'll keep an eye out for if it continues with other discs
