Re: SDFtool Flasher
EncryptedEggs wrote: Fri Jan 29, 2021 9:43 pm firmware.png
Ok trying now to figure out which firmware I should choose for my WH16NS40. I have the mk-firmware-pack-20200720 downloaded.
If you will be using MakeMKV (not anyDVD or DVDFab) then flash WH16NS60 1.02 MK from the "old"folder in MK firmware pack with "enc?" checked.
If you will be using either DVDFab or AnyDVD then I would suggest perhaps DE_LG_WH16NS40_1.02 or DE_ASUS_BW-16D1HT_3.02. To do this, follow the below steps:
1. Flash WH16NS40 1.05 MK from MK firmware pack with "enc?" checked.
2. Flash either DE firmware from the DE firmware pack (located in first post of this thread) without "enc?"checked.
EncryptedEggs
Re: SDFtool Flasher
Post by EncryptedEggs »
MartyMcNuts wrote: Sat Jan 30, 2021 1:11 am
I ended up going straight to WH16NS60 1.02 MK and yeah I just plan to use MakeMKV so I guess I'm good. But I am curious as the why the alternate plan if using anyDVD or DVDfab, like how would using WH16NS60 1.02 MK not play nice with those products
Re: SDFtool Flasher
EncryptedEggs wrote: Sat Jan 30, 2021 2:58 pm
WH16NS60 is an official UHD drive (not friendly) so any drive using it's firmware will not work at all with AnyDVD
DVDFab doesn't seem to like most of the MK firmwares but it does however work with DE_LG_WH16NS60_1.00 firmware.
ChesterMG
Re: SDFtool Flasher
Post by ChesterMG »
This tool is stunningly good!
I've never done a manual firmware update and was apprehensive. I bought an LG external slim BP60NB10, read most of the posts in this forum related to LibreDrive, identified the appropriate firmware version for my needs, read the documentation several times (following the old carpenter's proverb "measure twice, cut once",) and then updated the firmware in moments without any problems. MakeMKV immediately recognized the device as a LibreDrive, I ripped one of my Blu-Rays, and all is A-OK.
Thank you so much for this easy-to-use, powerful tool!
Sincerely,
Chester
Re: SDFtool Flasher
ChesterMG wrote: Sun Jan 31, 2021 8:39 pm This tool is stunningly good!
Sincerely,
Chester
You're welcome, Chester! Enjoy!! :D
rioan28
Re: SDFtool Flasher
Post by rioan28 »
Hi guys, I have the following drive.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KL5K9OD5857
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 3.10
I have tried downloading
DE_ASUS_BW_16D1HT_3.02 but getting this error:
"Command produced error code 0x8f052603"
Then I tried downloading
DE_ASUS_BW-16D1HT_1.01.bin and now I am getting this error:
Command produced error code 0x8f052400
What am I doing wrong? Trying to downgrade the firmware to rip UHD movies.
Mr_Orange
Re: SDFtool Flasher
Post by Mr_Orange »
Make sure that you are NOT checking the 'enc' box as it isn't required for your drive and firmware.
Re: SDFtool Flasher
rioan28 wrote: Tue Feb 02, 2021 9:41 pm Hi guys, I have the following drive.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
RTFM
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
Bluntman
Re: SDFtool Flasher
Post by Bluntman »
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
RTFM
Couldn’t agree more. There is a plethora of information on how to get this job done. Just put a little effort in. Not even much. Just the search field and 5 minutes of light reading.
Timberflake1983
Re: SDFtool Flasher
Post by Timberflake1983 »
Hi guys,
I've just bought a BU40N drive which has firmware v1.04. I'm trying to flash it to 1.03mk using SDFtool flasher but nothing happens when I click start?
I select my drive, leave it on 'Write Firmware', select firmware 1.03, click start and nothing happens, no error messages, nothing, and the status bar just shows 'Ready'.
I've tried running as admin and ticking 'enc?' with the same results. What am I doing wrong? Checked my .net framework and I'm on 4.8.
Re: SDFtool Flasher
You need to flash 1.04 MK with enc check first. Only then you can downgrade to 1.03 (enc unchecked!).
Timberflake1983
Re: SDFtool Flasher
Coopervid wrote: Wed Feb 03, 2021 7:27 pm You need to flash 1.04 MK with enc check first. Only then you can downgrade to 1.03 (enc unchecked!).
But literally nothing happens when I click 'Start'? I select my drive, pick 1.04 from the mk firmware folder, make sure WRITE firmware is selected, checked enc? and when I click start nothing happens. I tried running as admin again too.
Re: SDFtool Flasher
How is the drive attached? USB and extra SATA ports with non-mainboard chips can be troublesome.
Re: SDFtool Flasher
Also: You try to flash in native Windows and not a VM, right?
Timberflake1983
Re: SDFtool Flasher
Coopervid wrote: Wed Feb 03, 2021 7:50 pm How is the drive attached? USB and extra SATA ports with non-mainboard chips can be troublesome.
It's in a Vantec enclosure connected to the motherboard via 2 usb 3.0 ports
